Badger Patriot 105
    April 2004
Posted by keilau on Thursday, January 24, 2013 2:56 PM
DoogsATX, very well articulated points. I hope that the new bee on the market for his/her first airbrush understands too.
    September 2012
Posted by WutDaFunk on Friday, January 25, 2013 10:39 PM
What I am thinking now, is that I might get the Iwata airbrush because I would hardly ever used the .21 needle size as I am planning on using enamel paint most of the time. So the .35 needle and the .5 needle would be the better choice for me I think.
I don't think I would be missing out much because this would be my first airbrush so I would not know the difference between a badger an Iwata anyways. But since I do not know what kind of paint I would be using yet for sure, I may go for the Krome.
For right now I do not know for sure which airbrush I would be getting so my opinions may change in the near future. But in the meantime please keep the comments coming as they are a big help in helping me decide on which brush to get.
    April 2004
Posted by keilau on Saturday, January 26, 2013 7:55 AM
WutDaFunk
Don't decide until you try both the Iwata HP-CS and the Krome in your hand. Both are heavier, but well balanced airbrushes, compared to, like, the Patriot. They are the right weight for me. Both have very smooth trigger, but the Iwata is stiffer. If not sure which one you like better, go with your intuition.
The needles from both have identical 6 degrees linear flow angle, which determines the performance more than the difference in nozzle size. You will have a small learning curve to use and care for them. They allow skill build up faster than cheaper alternatives. It is very rewarding to learn from a better airbrush.
Either one would be good choice for a first airbrush. You may consider the price and local availability of spares (needle, nozzle etc.) as the deciding factor.
    February 2015
Posted by Bick on Saturday, January 26, 2013 9:03 AM
WutDaFunk,
If you might be interested in the Krome  ArtSupply has the 2 in 1 on sale now for $97.00 which I think is a good price.
Also, in you search for info and for another modelers view of airbrushes for scale models have a look at Paul Budzik's site. In addition to AB's, have a look around his site, he's a master modeler.
Unfortunately, since this is your first airbrush, you won't know what you like or dislike until you use it for a while. Any quality airbrush will spray paint for you but likes and dislikes become personal - as I've said, I like my H&S Evolution because it feels right to me when I use it, not because other AB's are bad. Whichever you buy it's is going to take some practice.  HTH and good luck with your choice.
    August 2009
Posted by denstore on Saturday, January 26, 2013 2:55 PM
Keilau, I just need to ask, are you absolutely sure that about the relevance of the angle of the needle? Proof that it matters more than nozzle size? Because I have my doubts about it. Not that it's irrelevant, but as with most things, one of many contributing factors. Others than nozzle size and needle angle might be nozzle outside angle, surface polishing of the needle, nozzle inside polishing (though I doubt it) nozzle cap design, needle cap design, air feed channel design, paint channel design and so on. To isolate one or two things as what determines performance, might be making it a bit too simple.
And maybe, how do we define performance? Is it detail capability alone?
I'm not saying that you are wrong, but sometimes things can't be explained by one single factor. And sometimes things are the opposite of what you think is logical.
Better an airbrush in the hand, than ten in the car....Stick out tongue
    April 2004
Posted by keilau on Saturday, January 26, 2013 4:13 PM
denstore
denstore, I am trying to address the misconception that Krome is a finer detailed airbrush than the HP-CS because it is 0.21 mm vs 0.35 mm nozzle. I found both provide very good atomization and draw tight line with minimum overspray. They are both good modeling airbrushes. I don't do free hand camo and is not in a position to judge the fine detailing performance of anything.
Yes, I believe that the large angles of the Patriot's bi-cone needle makes it very different from the Krome or the HP-CS. And I like the later much better.
Otherwise, I agree with everything else you said.
There are other things the end user cannot see too, such as the quality of the material of the needle and the annealing during manufacturing. Many users find difference in the springiness and resistence to damage of the needle from different brands. There is a reason to that. That's the crazy engineer in me talking.Devil
    August 2009
Posted by denstore on Saturday, January 26, 2013 4:43 PM
It was more of a rhetoric question, but also a reaction to the fact that I know of a couple of airbrushes that I've tried that didn't have a small angle needle, but still where excellent detailing airbrushes. I would say that most, if not all, manufacturers match their needles to perform good with the nozzle of choice.
Usually large nozzle airbrushes comes with steeper angle needles, and vice versa.
Sometimes the angles might be a bit larger or smaller depending on what characteristic of trigger response and intended use the airbrush designer is looking for.
Nozzle size is certainly not the only factor interesting for describing "performance", but in general, nozzle size will be a fair point of reference within the brand, and quite often between brands as well. Needle angle hasn't had that impact. And in reality, few brands even mention it.
    February 2015
Posted by Bick on Saturday, January 26, 2013 7:13 PM
Hi Keilau and Denstore,
I don't know how to quote from two separate posts so will use cut and paste
Keilau you wrote:
"I don't do free hand camo and is not in a position to judge the fine detailing performance of anything."
But that is exactly what you were addressing when you wrote:
I am trying to address the misconception that Krome is a finer detailed airbrush than the HP-CS because it is 0.21 mm vs 0.35 mm nozzle."
Whether the Krome or HPCS is 'better' at detailing might depend on what you mean by detailing. If you were an airbrush artist trying to airbrush eyebrows you would likely choose one over the other.
And Denstore wrote:
"Nozzle size is certainly not the only factor interesting for describing "performance", but in general, nozzle size will be a fair point of reference within the brand, and quite often between brands as well. Needle angle hasn't had that impact. And in reality, few brands even mention it."
I sure agree with this!! There's as much physics involved in the design of an airbrush as there is engineering. Take any airbrush currently made and replace ALL components with aluminum. I think it would function quite well - probably not for long but quite well initially.
BUT, let's not mislead the OP with all these details. I don't think it matters one iota whether the needle angle is 6 or 60 degrees but a nozzle/needle combo of greater than 0.2mm is probably easier to learn. The Patriot might just be the airbrush he likes but he won't know till he tries it, So, I say, Watdafunk, ignore what all us experts say and buy what looks good to you. If you buy a brand name one it's likely to work quite well; buy a Badger, Grex, Iwata, Paasche or H&S and start painting.
    April 2004
Posted by keilau on Saturday, January 26, 2013 10:28 PM
Bick
In my personal opinion, the Krome and HP-CS both have enough performance for the average modeler. In that, I mean linear trigger action and small overspray when painting smaller area. I do not see the 0.21 mm nozzle of the Krome giving it an advantage over the 0.35 mm nozzle of the Iwata. But the comment does not apply to Patriot. From the beginning, my comments are meant for the "average" modeler.
If someone believe that the Patriot is as good as the Krome, I disagree.
If someone believe that the Krome can do finer detail than the HP-CS in free hand camo modeling, show me.
Which one you believe will do a better job airbrushing eyebrows? And I am not an artist and have no opinion on that. That is not the original post asking.
    August 2009
Posted by denstore on Sunday, January 27, 2013 5:19 AM
Problem is that there's no right or wrong here. Sure, the Patriot might be a good start for a novice airbrusher, since the large nozzle almost eliminates the need of learning to thin paint properly. But on the other hand, it might not be the best for detail work, especially if the user hasn't understood the necessity of proper thinning of paint. And I suppose that the Patriot with the "superfine" conversion might give it detailing properties, but then the user must learn to thin anyway.
The Eclipse on the other hand has a medium nozzle as is, and used with modern modeling paint thinned about 50/50, will probably be enough for most modelers, both when it comes to ease of maintenance and use, and performance. I would almost say its foolproof. The real strength of the Eclipse is that there isn't any real need to change nozzles. It is good as delivered, for most modeling work.
For serious detailing work, there are plenty of airbrushes that are better, but few that are as versatile as the Eclipse. It is not my favorite airbrush. I like it, but as most jacks of all trades, its a master of none. To me, that owns a lot of airbrushes, of several brands, I prefer specialized airbrushes, made for one type of work alone. But that isn't the need of the average airbrusher (and in reality, probably not me either :D), and then the Eclipse will probably shine for people wanting one airbrush only.
    August 2009
Posted by denstore on Sunday, January 27, 2013 5:28 AM
And when it comes to the Krome, I can't really say, since I havn't tried it. But if it is similar to the Velocity that I tried, I would say that it is a better detailer than the Eclipse, but again needs good knowledge in thinning paint. And in my opinion it is a bit to large to be a really great detailer. If detail alone is what the buyer is looking for, I believe that there are better alternatives, even within the Badger brand.
    April 2004
Posted by keilau on Sunday, January 27, 2013 8:02 AM
denstore
The top of the line Badger detail brush is SOTAR 20/20 according to their promotion, at twice the price of the Krome. Never try it because I don't have a need to.
You said the same thing that I meant to say about Patriot vs. HP-CS. Only you articulate it better.
To me, the Iwata Eclipse is definitely not a Ferrari of airbrush, but a BMW 318 or Acura TSX. Cheap enough for the masses and good workmanship, but has many of the nice features that modelers are looking for and will last for a long time.
    September 2012
Posted by WutDaFunk on Sunday, January 27, 2013 9:56 PM
The reason I was mentioning sizes was because enamels are thicker, so thinning wouldn't be as critical. Also I'll be base coating/pre shading 99% of the time so wider coverage = better.
    August 2009
Posted by denstore on Monday, January 28, 2013 3:33 AM
That depends on what acrylics and enamels you chose. Some acrylics are very thin, but others, like Vallejo, are very thick. My guess is that it's the same with enamels. I have only tried a few brands, but there where differences.
I would say that if you at this moment plan to do lot of pre shade work, something with a little better detail control would be appropriate. Pre shade doesn't need to be hairline thin, but IMHO, it is better with a variety. And the covering layers after the pre shade must be thin, so I would say that a medium nozzle airbrush would be OK even for cover. Of course it depends on what scales you build, but 0.3-0.4mm is about perfect for 1/48 aircraft.
Take a look at the Grex XG as well. It is a very good airbrush. When I had my airbrush business, it was the airbrush that had the most satisfied customers.
    June 2010
Posted by montague on Friday, February 1, 2013 1:08 AM
I apologize for over reacting before. I hope that I didn't offend anyone.
    February 2015
Posted by Bick on Friday, February 1, 2013 7:43 AM
Didn't offend me - glad to see you still here and posting.
    July 2020
Posted by hulkctn on Thursday, July 9, 2020 4:21 PM
The Badger Patriot 105 comes in the box with 0.5 mm. But the main thing to pay attention to is that the needle tips are very sensitive. This is the point that badger already boasts. But I am on the wing that you should use it very carefully. The article I read gives more detailed information on this subject.
Posted by Wingman_kz on Friday, July 10, 2020 4:44 PM
All I can say is, it's too bad Doog doesn't hang around here anymore.
    July 2013
Posted by modelmaker66 on Saturday, July 11, 2020 12:39 AM
2013?
