H2O_MARK wrote: |
MikeV,
You recommended the Badger 100 over the TC Omni 4000 ,and before I hit the submit order button at Dixie Art tomorrow morning, I was just curious as to why. The Badger uses a multi-tip/needle setup..right? The Omni is single tip/needle...right? I was leaning towards the Omni for that reason though I really don't mind having a multi tip/needle setup.
Also does either of those airbrushes require a special hose, such as a Badger hose? Or can I continue to use my Paashce hose which has a built in water trap filter? Thanks |
Rob,
Either one of the airbrushes will work great for you so buy the one you like better.
I use the Omni 4000 more than all the others but it seems that the 100LG atomizes the paint a little better for freehand camo paint jobs for me personally.
Has your Paasche been used quite a bit over the years?
It is possible that your needle bearing is worn out and is not sealing well and that is why your airbrush is not picking up paint.
Also do this, pray a little windex, 409 or soapy water on the outside of the airbrush head and push the trigger down to see if there are a lot of bubbles there.
If there are you may want to get a thin strip of Teflon tape and wrap it around the threads there to seal the head better. Don't make the tape too wide as it can plug the holes in the airbrush body there at the tip.
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
