Revive felt tip marker
    April 2023
Posted by John3M on Monday, November 27, 2023 4:48 PM
Specifically the ones with .05 tiips or similar we use to scribe panel lines.
I draw black highly detailed scenes with fine point artist black tip pens. generally .003 and .005 in size. Sometimes they quit on me in the middle of a project. These pens are not inexpensive so to revive them and the ones similar to panel line markers like Gundm markers I take some fine grit sandpaper 1000 and maybe 1500 grit and lightly run the tip vertically across the paper 2-4 times I think what happens is the ink dries and blocks the porous surface. This trick has saved me many bucks...
    May 2009
Posted by Pawel on Tuesday, November 28, 2023 8:15 AM
Sounds like a cool trick to try... One more that could be handy would be to dip the tip in come Gunze Mr. Colour Thinner. That worked for me once or twice and I guess the thinner dissolved the dried ink - maybe that will help somebody..
www.vietnam.net.pl
    October 2019
Posted by Tanker-Builder on Tuesday, November 28, 2023 10:08 AM
Believe it or Not!
   This has happened to me with a Molotow pen too! I wash the tip off with Acetone and it works fine again. That's the large point version though. iIdon't know about the small tip one because mine got mis-placed.  I accidentally grabbed the "Mister Thinner" yesterday. It worked too! Not as well though, It took more soaking!
    April 2020
Posted by Eaglecash867 on Tuesday, November 28, 2023 7:38 PM
I used isopropyl alcohol just the other day to bring a Sharpie back to life after I forgot to put the cap back on it.  Just dipped the tip in and left it there for a couple of seconds.  Writes like new again.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    November 2023
Posted by REY SAREY on Wednesday, November 29, 2023 12:22 AM
Pawel
    November 2023
Posted by statenew on Wednesday, November 29, 2023 3:31 AM
It is really good
    April 2023
Posted by John3M on Wednesday, November 29, 2023 11:18 AM
Ive done the alcohol thing too with the micro size pens and had no luck.....
    April 2023
Posted by ctruss53 on Tuesday, December 5, 2023 12:53 PM
I am having similar problems with a .003 and a .005 marker. They work for like 5 minutes and then just quit on me.
I have soaked the tips in alcohol and Mr Leveling Thinner. Still don't work. I haven't tried other solvents yet.
And these are brand new markers.
Insert wise quote here.
-Chad
