Best way to cut brass wire?
    January 2004
Posted by knight667 on Friday, November 12, 2004 12:21 PM
I've been using regular wire-cutters, but they're not giving me a clean edge. What do you guys/gals use?
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
Posted by Anonymous on Friday, November 12, 2004 12:56 PM
With me, it depends on diamiter, I use a razor saw or Dremal (dimand cutting wheel) and finnish the edge with a small file and sand paper.
Posted by Anonymous on Friday, November 12, 2004 2:30 PM
Electrical wire cutters with a 180 degree cut, use them also for cutting parts of the sprue.
Finish off with a bit of sanding.
Posted by Woody on Saturday, November 13, 2004 12:15 AM
You can roll the brass rod under a large Exacto blade to produce a nice even cut. After the part is deeply scored it will snap off cleanly.
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
    January 2004
Posted by MusicCity on Monday, November 15, 2004 9:31 PM
QUOTE: You can roll the brass rod under a large Exacto blade to produce a nice even cut. After the part is deeply scored it will snap off cleanly.
Sign - Ditto [#ditto] - Or a single-edge razor blade. Put the wire on a hard surface (I use ceramic tiles from Lowes; about 0.50 each), put the blade on top, apply LIGHT pressure, and roll the wire. It will cut right through and give a pretty clean cut. Also works great on brass tubing.
    May 2003
Posted by jtilley on Monday, November 22, 2004 11:41 PM
Try a finger- or toenail clipper, which you can pick up at a drugstore for a dollar or two. Makes a nice, 90 degree cut in brass, copper, plastic, etc. The blades won't stay sharp forever, but the gadget is cheap enough to replace. And the other end has a nifty little file on it.
