When trying to accept a friendship notice I get the following message. What is going on?
Server Error in '' Application.
Object reference not set to an instance of an object.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. |
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.]
CommunityServer.Controls.LoginForm.OnInit(EventArgs e) +173
System.Web.UI.Control.InitRecursive(Control namingContainer) +333
System.Web.UI.Control.InitRecursive(Control namingContainer) +210
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +378
Version Information: Microsoft .NET Framework Version:2.0.50727.3603; ASP.NET Version:2.0.50727.3082
Berny
Phormer Phantom Phixer ![](http://i22.photobucket.com/albums/b309/berny13/f102copy.jpg)
On the bench
TF-102A Delta Dagger, 32nd FIS, 54-1370, 1/48 scale. Monogram Pro Modeler with C&H conversion.
Tamiya F-4D Phantom II, 13th TFS, 66-8711, 1/32 scale. F-4 Phantom Group Build.
