Need HELP-regulator in Badger seems not working
    October 2019
Posted by addictiya on Wednesday, October 23, 2019 8:25 PM
Hi!
I am a total newbie and I just bought a Badger TC910. Badger compressor or airbrush didn't come with any manual or explain how I should use it.
i connected Badger airbrush to it, the gauge shows 10 PSI, and I adjusted the regulator (I pulled it up and twisted it, pretty sure I am not doing it wrong)but the gauge doesn't change. Only when I turn it all the way down the gauge will lower to 0, but other than that, no matter how much I turn the regulator, gauge doesn't change, the air coming out of the compressor feels the same.
I really have no idea what could be causing this. thank you so much for whoever willing to answer this question
Tags: Badger , regulator , TC910
Posted by Tojo72 on Saturday, October 26, 2019 4:57 AM
I am sorry,I don't know about your question,but perhaps there have been no answers because no one noticed you down here,this is the section for technical questions relating to the forum.You need to post this in the Painting and Airbrushing Section.I am sure you will get some answers
    August 2005
Posted by EdGrune on Saturday, October 26, 2019 11:20 AM
Check the service page at Badger airbrush
http://www.badgerairbrush.com/Service-Supprt.asp
They will do service on their brushes and compressors.  Labor is free.  They charge for parts at a deep discount,   I want to say 60% off.
They do want $28 return postage.
I have had Badger do yearly maintenance on my brushes and an satisfied with their service
See the compressor product page
http://www.badgerairbrush.com/Compressors.asp
Double-click the picture of your compressor for the manual for your unit
    August 2005
Posted by Phil_H on Saturday, October 26, 2019 7:03 PM
Does it run up to pressure and stop or does it just run continuously? If it runs continuously, it would suggest there's an air leak in the system.
Check your air hose connections and that the drain valves in the bottom of the tank and the moisture trap are operating correctly and not venting air.
