Flat coat over gloss black
    November 2011
Posted by AUSboarhunter on Saturday, December 17, 2011 3:37 AM
Hello from Australia
My names Peter and I am a 16 year old junior modeller. I have just painted tamiyas 1/48 nighthawk in gloss black. This morning I proceeded to put on the decals and after allowing them to dry for a few hours I got set up to spray the plane in a flat coat as that's what the f117's finish is. I started to spray on the bottom of the plane to test and see how it was working. After about 10seconds the paint turned white and cloudy and I have had no other troubles with the flat coat before, however the models Were not black. The brand of paint I used was life colour flat coat LC-27. If any of you fellow modellers know of another brand of flat coat that you have used on a black plane that doesn't discolor the paint or a different technique to make the gloss black plane flat I would appreciate any help
Thanks guys!!!
Meanwhile I shall start my eduard mig-29 :)
    October 2007
Posted by Milairjunkie on Saturday, December 17, 2011 5:36 AM
I haven't used Life Color clears, but unless you happen to have got some of a bad batch it's possible that the clear isn't the problem. A couple of things come to mind;
Mixing - some clears require quite a bit of mixing & without it the flatting agent in the clear will often produce a whiteish finish.
Distance / pressure - if your spraying distance or air pressure were excessive this would cause the clear to start to dry mid flight, when this happens the paint is too dry to level out & create a smooth finish.
It might be worth experimenting a little away from the subject to see if you can get better results, if you can, you may find that hitting your F-117 with another coat of clear will sole the white finish you have.
    November 2011
Posted by AUSboarhunter on Saturday, December 17, 2011 5:24 PM
Thanks I will play around with it again today and do some more experiments
    August 2005
Posted by Phil_H on Saturday, December 17, 2011 5:40 PM
If it's simple hazing, this is very easily fixed. Apply a coat of clear gloss and the hazing should disappear.
If your flat coat went on clear and wet and dried to a hazy finish, I would be leaning towards insufficient mixing/stirring of the paint before reducing (thinning). At a stretch, humidity may cause similar problems.
My flat coat of choice is Gunze's Aqueous Clear Flat H-20 - luckily this is still widely available here in Australia.
    November 2011
Posted by AUSboarhunter on Sunday, December 18, 2011 2:58 AM
Thanks for the help guys, today i mucked around and tested a few things out. whilst doing experiments i came across a Vallejo flat clear coat and gave that a try. after several tests with thinning the coat down i found the result i was after on a black surface. i then sprayed the plane and all is good :)
tomorrow i shall continue on with the last few things and then start work on the base. when the plane is finished I'll try to get some pix up!!
    December 2010
Posted by TheWildChild on Sunday, December 18, 2011 5:07 AM
i had a similar problem with a black 1/24 scale sprint car, painted it, put decals on, weathered it, sprayed the clearcoat and turned almost everything white....my clearcoat was old, that was the problem with mine.
1/35 XM77  "Sledgehammer", 1964 Chevy Impala Derby Car
Whats next? Aircraft for Ground Attack Group Build
"I dont just tackle to make a play, I tackle to break your will." -Ray Lewis
"In the end, we're all just chalk lines on the concrete, drawn only to be washed away"- 5 Finger Death Punch
"Ahh, my old enemy.......STAIRS"- Po, Kung Fu Panda
    November 2011
Posted by AUSboarhunter on Wednesday, December 28, 2011 12:45 AM
