What's with the signature line limit?
    August 2005
Posted by corvettemike on Thursday, August 9, 2012 1:07 PM
I can't seem to make my sig any more than just one sentence. If I try to add an image (gb badge) it pops up in red letters that the maximum length is 512 characters and won't allow me to save. I tallied it up and my sig with the photo link is barely 123 characters, are there 400 or so invisible letters somewhere >.>
Rise my brothers we are blessed by steel in my sword I trust...
Arm yourselves the truth shall be revealed In my sword I trust...
Havoc Models
    May 2012
Posted by Old Ordie on Friday, August 10, 2012 5:16 PM
Corvettemike,
The 512 character limit refers to the html code required to display your signature line rather than the alpha characters you can see.  If you want to count the html characters that comprise the code for your signature line, go to your community settings, signature line section, and click on HTML on the command button line, and it will show you the code for your signature.  Count those characters (include the blank spaces), as those are the characters which are limited.  I'd say the single photo file on display on my own signature line below has well over 123 characters in just the line of code needed to display that one photo (maybe more than 223 characters - I haven't counted them).
I used to have the same problem you are having, until I combined my banners into one photo file.  Limiting the characters of code we can use to present a signature line is reasonable from an administrative point of view, so I personally don't have a problem with it.  On the other hand, I want to get the most mileage I can from the code I am allowed to use, thus my suggestion to combine all of your group build banners into one file.
Start by deleting everything from your signature line, which theoretically gives you 0 characters of code.  Save it.  Then add the single photo file of all your banners, then save it.  Then you can add text until you run out of html characters in your code.
Cheers!
Ordie
Flight deck:  Hasegawa 1:48 P-40E; Tamiya 1:48 A6M2 N Type 2 ('Rufe')
Elevators:  Airfix 1:72 Grumman Duck; AM 1:72 F-4J
    August 2005
Posted by corvettemike on Saturday, August 11, 2012 4:23 AM
Ok now it makes sense thanks. I was thinking it was a pure alpha character limit and it was glitched somehow.
Havoc Models
    May 2012
Posted by Old Ordie on Saturday, August 11, 2012 1:21 PM
You're welcome.  Looks like it's working for you, as I see a photo in your signature line now.  Just keep working with a single photo file by combining additional group build banners into it, and you should be fine (use the same photo file name each time you beef up your banner count, and you won't even have to change the code - easy peasy).  H2H.
