Missing smileys
    August 2006
Missing smileys
Posted by Gun Tech on Monday, December 11, 2006 9:48 PM
When I joined the forums a few months ago, we had a lot of smileys to choose from. Following the upgrade, they were missing for a while. Now, there back!   But it seems like a few of us don't have acces to all of them. Personnaly, I can see 49, but can use 56 (can't see the row with grumpy, but still can use it).......     Like I said, some of us can and the others can't.....      I was just wondering why....   browser problems maybe?
Cheers!
Edit:   If other buddies have the same problem , please make a post here Wink [;)]
Jean-Michel    "Arte et Marte"
    April 2005
  • From: I am at play in the fields of the Lord. (Texas)
Posted by m60a3 on Monday, December 11, 2006 10:46 PM
Sign - Ditto [#ditto]  plus "t".
 My "troll" won't show up and just barely the tops of the bottom row above the troll.
 60
"I lay like a small idea in a vacant mind" - Wm. Least Heat Moon "I am at the center of the earth." - Black Elk My FSM friends are the best.
    May 2005
Posted by Bgrigg on Monday, December 11, 2006 11:07 PM
I miss the the last three rows when the window opens, but the cursor "up" and "down" buttons scrolls through them all. My guess is the new software the forum uses is either not up to standards, or the browsers we use aren't. I'm posting this with Firefox 2.0.
So long folks!
    May 2003
Posted by DrewH on Monday, December 11, 2006 11:23 PM
I'm using IE 7 and am having no problems. Do not feed the trolls [troll]Yuck [yuck]Grumpy [|(] All work. I have no 'up / down' cursoe, just have to 'click' beside all the icons and move it down using the cursor. It works now, so I'm not complaining.
Take this plastic and model it!
Posted by cassibill on Tuesday, December 12, 2006 12:02 AM
I have the same problem as not being able to see them all but I click in the bottom right corner on the 100% and select 75% and them I can see them all. Although at the moment my whole toolbar is missing!!!!
cdw My life flashes before my eyes and it mostly my life flashing before my eyes!!!Big Smile The 1/144 scale census and message board: http://144scalelist.freewebpage.org/index.html
  • From: Modeling anything with "MARINES" on the side.
Posted by AH1Wsnake on Tuesday, December 12, 2006 12:17 AM
I too am missing smileys. When the new window opens to select smileys, it appears that some bottom rows are missing. I cannot scroll down or resize the window to see what they are.
"There are only two kinds of people that understand Marines: Marines and those who have met them in battle. Everyone else has a second-hand opinion."
    March 2006
Posted by Shellback on Tuesday, December 12, 2006 12:21 AM
  my icon display is 7x7 , no way that i know of to expand it
Posted by cassibill on Tuesday, December 12, 2006 1:10 AM
I can't resize the window either. That's why I shrink the smileys.  You might have to squint a little tomake thm outbut they are all there.Do not feed the trolls [troll]
Posted by berny13 on Tuesday, December 12, 2006 6:02 AM
I am also having a problem.  It will not let me resize or drag the corner at all.
Berny
 Phormer Phantom Phixer
On the bench
Posted by David Voss on Tuesday, December 12, 2006 9:51 AM
I know, I know...  I don't know why the popup windows were originally coded to not allow them to be resized.  It's on my list but it's a rather long list. Black Eye [B)]
David Voss Senior Web Developer Kalmbach Publishing Co. Join me on the FSM Map
Posted by espins1 on Tuesday, December 12, 2006 10:14 AM
If you're using IE7, just go to the bottom right corner of the smiley popup and change it to 75% on the zoom.  You'll have to do that each time you want to access the lower buttons, but that's a work around until David can get to fixing that.  Smile [:)]
Scott Espin - IPMS Reno High Rollers  Geeked My Reviews
Posted by berny13 on Tuesday, December 12, 2006 10:16 AM
Thanks David.  What else is on the list we may not be aware of?  Trying to catch us by supprise, are you.  Confused [%-)]
Berny
On the bench
Posted by David Voss on Tuesday, December 12, 2006 11:26 AM
I'm sorry, sir.  That information is CLASSIFIED. Laugh [(-D]
    August 2006
Posted by Gun Tech on Tuesday, December 12, 2006 6:11 PM
Thanks David
Posted by David Voss on Wednesday, December 13, 2006 4:27 PM
I just posted an update to fix a couple of items on the forum.
  • The smiley window is now be scrollable & resizable.
  • The images window is now wider but just in case it is also scrollable & resizable.
  • The font size in the posting editor was increased a tiny bit.
  • The strikethrough is working (has for awhile).
  • I added in a compression script that should make the posting page load much quicker.
  • When posting a url using brackets, it will work with or without quotes around the url.  With quotes was not working after the new posting editor was added.
Let me know if your smilies are all there now. Wink [;)]
EDIT: I uploaded a cheat sheet with all the different smilies with their corresponding bracket code.
    April 2005
Posted by m60a3 on Wednesday, December 13, 2006 4:39 PM
 Wow, good job David. I even got this guy back,  Do not feed the trolls [troll].
 Thanks again for the good work you do. And the rest of the staff as well. Make a Toast [#toast]
   60
Posted by espins1 on Wednesday, December 13, 2006 5:51 PM
Awesome!  Thanks David!  Make a Toast [#toast]
    August 2006
Posted by Gun Tech on Wednesday, December 13, 2006 5:58 PM
Party [party]          Awesome job David!    Thanks!
    March 2006
Posted by Shellback on Wednesday, December 13, 2006 6:41 PM
Thanks DV ,Thumbs Up [tup]
Posted by berny13 on Wednesday, December 13, 2006 8:08 PM
Thanks David.  Thumbs Up [tup]
Berny
On the bench
    May 2003
Posted by DrewH on Wednesday, December 13, 2006 9:03 PM
You da MAN!! Thanks for the effort DavidBow [bow] Much much appreciatedApprove [^]
    November 2003
Posted by chopperfan on Thursday, December 14, 2006 10:22 AM
Big Smile [:D] Way to go, DV!!!!! Bow [bow] Make a Toast [#toast]
Also, thanks for the quick response on the link question.  You are most definately "DA MAN!!!!" Thumbs Up [tup]
Randie [C):-)]Agape Models Without them? The men on the ground would have to work a lot harder. You can help. Please keep 'em flying! http://www.airtanker.com/
    February 2006
Posted by ruddratt on Thursday, December 14, 2006 10:24 PM
Kewl! Cool [8D]
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
Posted by AH1Wsnake on Friday, December 15, 2006 8:23 PM
Thank you Mr. Voss, sir! Now I can see what all those smileys on the bottom row were!Chef [C=:-)]Captain [4:-)]Dunce [D)]Grumpy [|(]Mischief [:-,]Pirate [oX)]Laugh [(-D]Boohoo [BH]Burger [BG]Party [party]Propeller [8-]Yuck [yuck]Taped Shut [XX]Make a Toast [#toast]
