Question on plastic models that have pieces that don't conform to the whole model.
Jan
    January 2009
Posted by Jan on Sunday, January 4, 2009 11:25 AM
Hi To Everyone:
 My name is Jan and I'm new to modeling.  I bought myself a couple of plastic car models and when I was trying to assemble them I had noticed that some of the plastic parts after assembling and during assembly have a tendency to make the model not sit flat on all four wheels.  I noticed during assembly that some of the parts do not lay flat.  Is there something I can do the correct this problem?  I thought I would try to hold it over the burner for a little bit to soften up the plastic but that didn't seem to help.  I would love to indulge myself into more modeling but would like to solve this problem.  Can anyone help?
Jan
Jan
    February 2007
Posted by DesertRat on Sunday, January 4, 2009 12:22 PM
Hiya Jan, and Sign - Welcome [#welcome]t the Forums!
I really don't know much about car kits. However one idea you might look into is the fit of the parts before gluing. It maybe there is some piece of flash styrene from the injector pin marks or some piece of debris causing your misalienment.
However, I am mostly an aircraft guy. I'll defer to the expert car guys hereWink [;)]
Warmest regards,
Roger
    September 2012
Posted by namrednef on Sunday, January 4, 2009 12:23 PM
Hi Jan andSign - Welcome [#welcome] to the forums!
I'd suggest that you visit the Auto Forum.....surely others have had the same problem.
It may be just that kit.....or a bad molding. Someone will help you!Propeller [8-]
    August 2006
Posted by Gun Tech on Sunday, January 4, 2009 2:11 PM
Welcome to the forums Jan!
Like others said, take a look in the auto forum, others proably encountered the same problem.
When I want to fix up an aligment problem, I use a hair dry. It enables me to apply the heat more precisely. Like this little alignment problem that I fixed:
But be carefull about how warm the air is, or this may happen:
Hope it helps!
Jean-Michel    "Arte et Marte"
Jan
    January 2009
Posted by Jan on Monday, January 5, 2009 4:02 AM
Thank you everyone for your advice and direction.  I look forward to communicating in the future. I'm almost positive I can learn something from all of you.
Thank You
Jan
    September 2003
Posted by Daywalker on Monday, January 5, 2009 7:27 AM
Sign - Welcome [#welcome] Jan!  Glad these fellas were able to help you out.  A good bunch of people here. Approve [^]
Frank
    August 2006
Posted by wyoroy on Monday, January 5, 2009 9:14 AM
Sign - Welcome [#welcome] to the Forums Jan.
Roy (Capt. Wyoroy FAAGB/USNFAWGB)
John 3:16
    December 2007
Posted by mg.mikael on Monday, January 5, 2009 7:41 PM
Sign - Welcome [#welcome] to the forums, Jan!!! Hope to see you around!Wink [;)]
"A good plan executed now is better than a perfect plan next week." - George S. Patton
  Photobucket
