Newbie requesting some help
    July 2019
Posted by Kopite on Wednesday, July 24, 2019 3:48 AM
Hi All.
i'm from melbourne, australia and recently only started up this hobby and i have a few questions about it.
I'm only on my second model and i've decided to stick to cars.
firstly i'm confused about glues, i currently use the extra quick think tamiya glue that everyone recommends, online i've read that the setting time can be anywhere from 2 mins to 2 days? can some please clarify  for me how much time i should leave peices to set? and how much really should be applied?
Also since using this glue i've notice that it removes bits of paint making the model splotchy looking.  luckly on my 1st car i was going for a "my 1st car look" so it worked out, this time i'm trying to make a nice new glossy one
is there something i'm doing wrong with the gluing or painting process?
what could be causing my paint to come off?
thanks in advance for your help, and sorry if this is the wrong forum, didn't see a beginners section.
Thanks
Kopite
    September 2003
Posted by checkmateking02 on Thursday, July 25, 2019 4:03 PM
Welcome to the Forums!
I use different glues for different purposes, from CA (superglues) to the usual liquid plastic glues.  There are still uses even for the old tube-type glues.
I think 2 minutes is too quick to expect a fully-cured bond.  I'd give it at least a couple of hours and probably overnight before I'd do any more with it.
If you get glue on top of any painted part, it's going to adversely affect the paint.  The exception is white-type-craft glue.  That should wipe off with a damp cloth, but white-craft type glues also don't produce a solidly fused bond.
When using solvent-type plastic cements like the Tamiya extra-thin, it's best to glue first, then paint if you can.
I'm sure others will post with more information, too.
    September 2012
Posted by GMorrison on Thursday, July 25, 2019 4:22 PM
I use a fair amount of CA because I model ships and I have to paint quite a few parts prior to assembly.
Be aware that it will permanently fog clear styrene. Even just the fumes. Ships don't have any clear parts.
    July 2019
Posted by Robotism on Thursday, July 25, 2019 5:04 PM
If you're using the square bottle with the green lid I think you are that's not glue. That's plastic cement, it's a type of solvent that makes 2 pieces of plastic melt at the edges and smush together to form 1 piece. Sort of like melting 2 ice creams then refreezing it. If you're going to prepaint parts you want to be using super glue not plastic cement since it acts as a bonder between parts not melting and resolidifying them.
A really glossy finish is one of the hardest builds to pull off. Even the smallest mistake can ruin one of those. For your second build ever you would likely be better focusing on the fundamentals and going for a more standard finish. Your first few kits will be full of silly mistakes we all made and learned not to repeat. It'll be some where in the early double digits you really find your flow and can build a kit without any major mistakes. It's usually best to save that kit you really really want to do for a bit later and focus on cheap easy to get kits first off so it doesn't sting so bad when you mess them up.
Dr. Faust has some pretty good beginners tutorials you might find helpful to get you off on the right foot.
Posted by Tojo72 on Thursday, July 25, 2019 7:28 PM
Hello and welcome to the forums,glad to have you aboard.
    July 2019
Posted by Kopite on Thursday, July 25, 2019 7:32 PM
Thanks Everyone for the advice, i've learned loads already.
can anyone recommend thier go to CA glue? or clear super glue.
I'm in australia so i dont know how much the brands differ.
Sounds like i'm using the wrong glue for the wrong purpose
so lesson learned there!
thanks all so far for your friendly and helpful answers
    July 2019
Posted by Kopite on Thursday, July 25, 2019 7:34 PM
Thanks!
    September 2003
Posted by checkmateking02 on Friday, July 26, 2019 1:55 PM
Kopite
Zap or Zap-a-Gap used to be my usual choice, but I had a couple bottles that didn't perform like they used to.  Don't know if it was old glue, bad batch or a change in the forumlation.
Bob Smith Ind. makes a decent brand I've used.  Other stores offer their own label--like Freetime Hobbies in Georgia, USA.
I don't know what's available down under.  You may have to experiment.  Once you get the hang of it--and it took me a while--it works well for most things, except clear parts.  Usually you'd want to go with a white craft type glue for clear parts without much stress on them.
Good luck!
    September 2006
Posted by the Baron on Friday, July 26, 2019 2:17 PM
Welcome to the forums!
You might want to have a look down in the Tools forum, too:
http://cs.finescale.com/fsm/tools_techniques_and_reference_materials/f/23.aspx
I suspect you'll find a lot of info about various glues there.
    July 2019
Posted by Robotism on Friday, July 26, 2019 2:50 PM
Loctite if you want it to dry fast and gorilla if you want it to dry slower so you can adjust it before it dries.
Even cheap super glue will do. There's people who do amazing work with 10 for a dollar packs. It's a matter of finding what works for you in your price range.
    June 2014
Posted by Tanker - Builder on Saturday, July 27, 2019 11:13 AM
Beginner?
   That's okay, but there is a lot in tools or auto. Now as to your glueing .Glue most parts Before painting .Glue finish parts after cleaning an edge to plastic. Then touch it up. If you use Cyanocrylate ( Super ) glues there is one thing you need to know .It does not hold well if you torque or twist the piece afterward or if it's in a bind .
