revell f-106 delta dart/ beginner
    October 2007
Posted by baillie1 on Monday, December 31, 2007 6:49 PM
hi, new to modeling, lots to learn. i was in the USAF back in 1970 stationed with f-106s in maine so i thought it would be neat to have a replica of the plane i worked on for display.purchased a 1/48 scale revell kit and things are just not progressing smoothly.  Canopy is wider than the fuselage. also need help with which glues to use.I love tenax r7,seems to have a strong bond. do you experienced modelers build an untire model with tenax??? which glue should i use to bond wheel struts to the wheel well that are going to support the weight of the model? also,why do i need to use fine sandpaper?, won't the paint fill in nicely and give a nice uniform appearance even if i use a coarse paper? i will be purchasing a 3rd f 106 and try again,if it doesn't come out decent i'll try a 1/72 scale same aircraft.
    August 2006
Posted by wyoroy on Monday, December 31, 2007 9:26 PM
Sign - Welcome [#welcome] to the forum.  I use Tenax, CA, liquid cement and tube cement.
Roy
Roy (Capt. Wyoroy FAAGB/USNFAWGB)
John 3:16
    September 2003
Posted by Daywalker on Tuesday, January 1, 2008 8:28 AM
Hiya, and Sign - Welcome [#welcome] to the madness!
To answer some of your questions, I use a liquid glue like Tenax for most assemblies, except the canopy, wheels, and parts that I leave off until after painting.  It is a fairly strong glue, but is easily weakened by paint in the area to be glued.  For a structural joint, I usually use super glue or epoxy for strength.  As for fine sandpaper, I usually start with 400 grit and work my way up to 1200.  If you sand with anything coarser than 600 and don't smooth out the sanding marks, the scratches will probably show through the finish.  The goal is to get as little paint as possible on the model so as not to obscure the fine surface detail.  I hope that helps!
Frank
Posted by rjkplasticmod on Tuesday, January 1, 2008 8:53 AM
Welcome to the Forums Sign - Welcome [#welcome].  Like others, I use several different glues in building a model.  Tenax for most of the major assembly, CA or Epoxy for some of the work & white glue for canopies & windscreens.  For landing gear, I prefer to use Epoxy as it gives time to get the adjustments correct.
Regards,  Rick
    August 2006
Posted by Gun Tech on Tuesday, January 1, 2008 4:09 PM
Welcome to the forums!
Jean-Michel    "Arte et Marte"
