Rolling photoetch gun barrel coolling jackets
Posted by echolmberg on Monday, November 10, 2008 1:57 PM
Help!
I ordered an Eduard PE set for my B-17.  One of the components in this set are the perforated cooling jackets for the .50 cal guns.  However, they come flat.  After doing exstensive research, I've discovered that the gun barrels were, indeed, round.
Now that we've extablished that, how do I turn the flat PE part into a round tube?
Help!
Thanks!
Eric
    January 2007
Posted by the doog on Monday, November 10, 2008 3:29 PM
Not an easy thing to do. But try this:
Heat the PE part up over your stove burner; let it get good and hot (might want to try it with a spare piece first). This is called "annealing"; it softens the metal. Then find a cylindrical object smaller than the actual tube that you want to make, and bend the PE around that piece. You might want to bend it around a piece of steel rod, or maybe even brass? If the metal is soft enough, you should be able to do it with your fingers somewhat. It ain't easy to do, but that's how I do it when I need to get cylinders.
Posted by echolmberg on Monday, November 10, 2008 4:55 PM
Thanks Doog!  I've heard of the annealing trick (heck I even had a test on it last week!).  But now it's time for my stupid question of a lifetime.  We can wait until the metal has cooled, right?
Signed,
Fred Smith (not my real name)
    January 2007
Posted by the doog on Monday, November 10, 2008 5:07 PM
Signed,
Yes, wait for it to cool--it should be softer; if it's not, then heat it more. I think you have to get it to blacken, pretty much. Don't take my word for it though; some PE is different than others. Best to try it first with a scrap piece.
    June 2008
Posted by Hans von Hammer on Tuesday, November 11, 2008 11:35 AM
Make sure it's brass you're annealing... If it's aluminum, you'll be sorry...
Posted by echolmberg on Tuesday, November 11, 2008 11:43 AM
Hans, why do ya gotta screw things up for me???  I think it might be Al.  If it is, in fact, aluminum, what are my options?  I've never worked with the aluminum stuff before.  Will it be softer to the point where I don't have to anneal it like brass?
Eric
    February 2005
Posted by RadMax8 on Tuesday, November 11, 2008 11:57 PM
Eric, you might want to go to the aircraft section and check out chukw's tutorial on how to build a Helldiver. He gave a great show on how to do those flat jackets into easy cylinders.
    June 2008
Posted by Hans von Hammer on Wednesday, November 12, 2008 4:09 AM
Eric
LOL... Heh.. Consider what it would have looked like had I NOT screwed things up for ya...
Truthfully, I'm not the best guy for PE tips, since I don't use much of the stuff.  I've only used what's come with the Pro Modeler kits.  But speaking metalurgically, aluminum is softer than brass and can't be annealed.
Posted by echolmberg on Wednesday, November 12, 2008 11:54 AM
You guys are all great!  Thank you for the great info.  And Rad, I'm going to look for the build on the Helldiver too!  Thanks!
Eric
PS. Hans, my little quiz I had last week on annealing covered iron, not aluminum.  LOL!  No wonder I didn't know about it.
    June 2005
Posted by smokinguns3 on Wednesday, November 12, 2008 7:12 PM
yes you can aneil aluminum http://www.key-to-metals.com/Article139.htm
Rob I think i can I think i can
    June 2008
Posted by Hans von Hammer on Thursday, November 13, 2008 4:51 AM
Sorry, Guns....  Didn't think I'd have to be that specific for a modeling question, but I'll ammend my statement to say that, "You can't anneal photo-etched aluminum parts for small-scale models in the traditional manner of most non-ferrous metals and alloys due to the extremely low melting point of the material and the average modeler's lack of precision thermal measuring equipment and the varibles of such a process, especially in the the amount of work-hardened crystalization already undergone in the process of manufacture and shaping of the basic stock material used for the etching..."  It's not very often I get asked, "What time is it" and need to answer with a detailed explanation of how time works and how to build a reliable and accurate watch to monitor it...
Usually, "Three O'clock", or something like that, suffices...  I'll strive to be more detailed in the future....
Wink [;)]
    September 2007
Posted by firesmacker on Thursday, November 13, 2008 8:01 AM
Wink [;)]
Ok, now this one actually made me laugh out loud at work. Awesome!
Posted by echolmberg on Thursday, November 13, 2008 8:47 AM
Well I, for one, am NOT laughing.  I just ordered a blast furnace and matching annealing ovens.  They're supposed to get delivered tomorrow!  Curses!  Curses!
Eric
    June 2005
Posted by smokinguns3 on Thursday, November 13, 2008 2:13 PM
 echolmberg wrote:
Help!
Help!
Thanks!
Eric
if you useing eduard pe you will fine ive used plenty of pe and ive never seen it done with aluminum.
Posted by echolmberg on Friday, November 14, 2008 8:54 AM
I'll tell you one thing, I went back and looked at that Helldiver build.  All I can say is "Will someone please pick up my jaw??"  Absolutely amazing.  I'd seriously like to know what the guy does for a living to have all that time to do all the wonderful work he did!  I just have an 8-5 desk job plus a wife and two kids and I'm lucky if I get two or three hours of build time in a week!  Last night I airbrushed the bottom of my P-51.  That's all I had time for!
But I digress.  Regardless of the material (brass vs. aluminum), I picked up some wonderful tips from reading that build.  Actually, I picked up a LOT of tips as well as inspiration.
Eric
    February 2005
Posted by RadMax8 on Friday, November 14, 2008 12:30 PM
He's an artist for a living  I think. Yeah he's quite amazing. I'm going to have to try the drill bit idea. Let us know how your barrels turn out
    June 2008
Posted by Hans von Hammer on Saturday, November 15, 2008 7:15 AM
I'm kinda in the same boat as ChuckW... Although I'm not a pro modeler or a paid artist, I build about 40-50 hours a week and actually work my "real" job about 10-20...  I got my Army pension, and I manage an apartment building for a living as a supervisor, general handyman, and rent collector...  I get a smallish salary and a free apartment out of the deal, so my supervisor pay goes into models, supplies, and tools...  Problem is, I have about 10 dioramas in progress right now, so having all that time can be a draw-back as well... When I reach a mandatory stopping point on one, I'm liable to start another project, rather than pick up on a  partially-done one...
