trumrreter 1/32 scale sbd -3 ver,s sbd-3/a-24a
    June 2010
Posted by 5-high on Sunday, August 8, 2010 12:54 AM
5 -high .....here i was woudering what,s the diff ..about the the two ..i know one is the midway ..........clear edition???
but what is the real deff ??
i look at the two ..........there,s no deff??
whats up???????Confused
    April 2009
Posted by deafpanzer on Sunday, August 8, 2010 9:35 AM
I assume you are talking about Douglas SBD Dauntless... perhaps you should post your question in the Aircraft forum to get answers if nobody is able to help you here.  I assume it has something to do with the plastic being clear that you can see thru.  I am sure guys in Aircraft can help you... now you have made me curious about this.
Andy
Posted by Jeeves on Monday, August 23, 2010 7:56 PM
If you mean between the -3 and -5, there are a few-- but most not easily noticeable-- like engine variants and inner system differences.  However-- cowl flaps are a bit different, as well as the rear gun which goes from single to two... the A-24 is the Army variant, so no tailhook...a pneumatic tail wheel instead of the hard rubber, and different main gear treads-- but the kits usually give you both options.
