Hi im using gamesworkshop paints. And wan't to use distilled water but can't find it anywhere.
so i got deionized water. Does that have the same effect?
thanks
Odd, distilled water should be easy to find as it is used for ironing among other things. It does appear that deionized water should work for you though, although it may be more expensive. Apparently it is usually made from distilled water.
http://www.ehow.com/about_5398356_deionized-water-vs-distilled-water.html
As far as I understand, distilled water is recommended over tap water because it doesn't have minerals that can build up in the paint over time.
I use GW paints along with others, I use tap water for clean up and out of the bottle thinning (washes and such), and distilled water for thinning the paint in the bottle when it gets too thick.
I think it is important to point out distilled and deionized water is not drinking water. A little won't hurt you but, it basically dilutes your body fluids. I have read about health nuts literally killing themselves by drinking gallons of distilled water to cleanse their system and throwing their body chemistry all out of whack. Added just in case you get thirsy at the bench, go to the tap, or grab a bottle of drinking water.
Grocery and drug stores stock it. Just ask the clerk!
Gerald "Hawkeye" Voigt
Auto supply stores too. It's used for topping off car batteries.
Cary
thanks everyone! Ive just used deionized water. and is working okay.
thanks again
Tom
To some extent, one term indicates how it was made (distilled water is made by distillation) and the other indicates what it contains (no ionizable minerals). I believe for paints, decal applications, etc. it is the ion content that creates the major problem, so deionized water should be pretty good. I would assume most dionized water would not contain much dissolved solids that are not ionizable, but I suppose it could.
De-ionized water is more or less the same as distilled water, though distilled water will have zero mineral content. Both should be easily found, check the water aisle at the grocery store. The kind I buy is the local grocery's "Western Family" brand, and was about $1 per 4 liters, which is a tiny bit bigger than the US gallon.
So long folks!
Is holy water the same thing?
How many impurities are there (really) in tap water that would interfere with paint mixes?? I'd be tempted to give the "free water" a shot & save the expensive stuff for, uhh, drinking!
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
Manstein's revenge Is holy water the same thing?
actually Manny lets use a visual example...
Use Distilled water to wash your cat and you get....
Use Deionized water and the results are....
get the picture....
carlos
chucky17 thanks everyone! Ive just used deionized water. and is working okay. thanks again Tom
Manstein's revenge I was in a pich once and used cat urine with no ill effects...
uhhh, for washing, painting, or drinking?
VanceCrozier Manstein's revenge: I was in a pich once and used cat urine with no ill effects... uhhh, for washing, painting, or drinking?
.....for de-lousing........meouw.....
Just go to WalMart or Walgreens or RiteAid. That's where I get mine
