doesn't the approach have to be different for the four different types of "accurate modeling"? (with each being equally valid from my point of view)
one approach is to model "a Skyhawk with accurate markings, with any weapons that a Skyhawk could carry"
another approach is to build "a Skyhawk from the USS Hancock cruise in 1973, with any weapons that could have been onboard the Hancock at that time"
another aprroach is to build "the Skyhawk, NP-401 BuNo 155022, as it appeared on the same Hancock cruise"
yet another approach is to build the above aircraft, as " Lady Jessie, with the markings and weapons as carried on the first flight the morning of (pic any exact date in the 1973 cruise), with super pilot Sam at the controls"
that list above could produce 4 different models,,,,,or the same exact finished model, just worded 4 different ways
as you work down from top to bottom,,,,,,the accuracy issue becomes more and more important, and the burden of "proof" becomes heavier,,,,,,,,and the opportunity to pick the nits increases
all 4 methods are equally valid,,,,,,,along with the "I want one model of a Skyhawk on my shelves, and Lady Jessie looks like a pretty aircraft"
the arguments start when someone claims to build to the 4th (strictest) standard,,,,,,but, puts double striped bombs on a 1965 Skyhawk model,,,,,,,,,sure, he can put them on there,,,,,,it's his model,,,,,,,,but, don't claim it's built to "4th standard", because it's not
Rex
