Runs in Future
    May 2010
Runs in Future
Posted by salvine on Friday, October 28, 2011 12:54 AM
Tried searching for info but seem to have issues with searching here. Any tips? Anyway, I have a couple runs and I was under the impression that adding more future later would soften the prev coat and smooth out. That does not seem to be the case. Just sand and reapply?
Thanks, Steve
    March 2007
Posted by bondoman on Friday, October 28, 2011 1:43 AM
No don't do that. Soak it in ammonia and wipe it off after an hour or so. Windex is a great solution because it's diluted. That will do it, and then clean it with soap and water. Reapply the future. The trick with future is that it initially has the consistency of water but very quickly turns into syrup. For canopies, i hold them with a tweezer for a good five minutes over/ on a piece of paper towel and let it all slide off.
For a model, you have to kind of rotate it around for 15 minutes or so to let it set.
    August 2005
Posted by Phil_H on Friday, October 28, 2011 2:49 AM
bondoman
Ok if your model is painted with enamels. However, if it's painted with acrylics, say goodbye to the entire paint job.
    May 2010
Posted by salvine on Friday, October 28, 2011 11:20 AM
Paint is acrylic so I may need to do some sanding. I might try some Windex on a rag and lightly rub to see what happens.
    January 2010
Posted by CallSignOWL on Friday, October 28, 2011 11:32 AM
salvine
Thanks, Steve
Ive had runs before after applying Future too heavily. The easiest way to get rid of them is to soak a Qtip in future and scrub at the puddle. After a moment, the puddle will be gone with no damage to the underlying paint.. This is the quickest, easiest, and least damaging technique I've found in dealing with runs/puddles of future. No sanding needed! Smile
Now that I'm here, where am I??
    March 2010
Posted by Hercmech on Friday, October 28, 2011 11:43 AM
Good tip Owl
13151015
    June 2008
Posted by Hans von Hammer on Friday, October 28, 2011 4:41 PM
Testor's Gloss Coat...
3 minutes..
Done...
Wink
    January 2003
Posted by TomZ2 on Friday, October 28, 2011 9:48 PM
Runs in Future” is my Indian name.
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    March 2007
Posted by bondoman on Friday, October 28, 2011 11:41 PM
Hans von Hammer
3 minutes..
Done...
Wink
Oh I am with you! I don't like Future at all except for the clear parts. It is way too thick, acts in strange ways with Micro sol and set, leaves brush marks and is generally hard to control.
I always have a stash of Testors Dulkote and Gloskote in the little rattlers. I've tried Krylon, the various artist fixatives etc. and the good thing abt Testors is it goes on very thin.
    February 2011
Posted by Reasoned on Saturday, October 29, 2011 9:04 AM
bondoman
 Hans von Hammer:
3 minutes..
Done...
Wink
Ditto
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    June 2008
Posted by Hans von Hammer on Sunday, October 30, 2011 10:28 AM
I've tried that dipping-thing  too...  But it just doesn't look right afterwards... The canopies are too clear, if you get my drift...
    March 2007
Posted by bondoman on Monday, October 31, 2011 1:20 AM
Clouded canopies are definitely a 6 to a 7 on the SCRIM. Many the Frog and Heller, and wait for it, Mach 2 kit have good representations of distorted vision plex.
In fact the Mach 2 Mariner I have is so bad it's probably a 10.
No breasts. Sea Blue-fu. Warped wing-fu, Garbage gun castings. Gratuitous decals and extra vomit for wing halves that are 1/4" different in length and French origin. HvH sez "check it out".
