Who Makes Treadplate in 1/24 or 1/25 scale?
    September 2005
Posted by Sprue-ce Goose on Sunday, January 15, 2012 10:00 AM
I am in the process of accumulating materials to scratch build some 1/25 th scale armor and will need
a decent looking treadplate pattern for the turret basket floor plates.
My local Hobby Town has Plastruct Diamond Pattern treadplate labeled as 1/48th scale.
Plastruct's online catalog lists:
DIAMOND PLATE
G (1:24) SCALE
CODE: PS-153
However, I have not seen examples in stores.
Has anyone recently seen good examples of Diamond Treadplate in 1/24th or 1/25th scale?
If so , who makes the product?
Unfortunately, there is a considerable difference in size and appearance between tread plate patterns supplied with the samples I have in my possession:
Revell 1/25th scale Peterbuilt truck and Tamiya 1/25th scale armor.
Thanks for your help.
Posted by Don Stauffer on Sunday, January 15, 2012 11:25 AM
If you cannot find actual treadplate in styrene sheet, Archer makes dry transfers of the diamonds so you can add it to plain styrene sheets, though I don't remember what scales they make it in.
    September 2003
Posted by dpty_dawg_ca on Sunday, January 15, 2012 11:41 AM
I use Plastruct treadplate for 1/25th scale modeling. Their sizing is way off though. At one time their 1/48th scale chequerplate was identical to what AMT used on their firetrucks. They then called the same size stuff HO scale.  You need to check it out at in person because if its off the web the sixing may not agree with the actual scale you want. The stuff they call 1/25th scale has diamonds that scale out to 2-3 inches.
Italeri has some chrome plated tread plate in thie truck accessories kit also
Thanks
Carl
    December 2010
Posted by TheWildChild on Sunday, January 15, 2012 2:39 PM
i dont know if he is still in business, but try Fred Resin Workshop. theres was pretty good. i used it on a 1/25 tractor trailer i did about 2 years ago and it is pretty good.
1/35 XM77  "Sledgehammer", 1964 Chevy Impala Derby Car
Whats next? Aircraft for Ground Attack Group Build
"I dont just tackle to make a play, I tackle to break your will." -Ray Lewis
"In the end, we're all just chalk lines on the concrete, drawn only to be washed away"- 5 Finger Death Punch
"Ahh, my old enemy.......STAIRS"- Po, Kung Fu Panda
    September 2005
Posted by Sprue-ce Goose on Sunday, January 15, 2012 4:56 PM
dpty_dawg_ca
Thanks
Carl
I agree checking in person is necessary.
I was just checking one brand at a LHS ( don't recall the name right now ) but the 1/24 version was dual  diamond tread plate.....can't use it on WWII armor, I presume.
A 1/48th version looked better as far as spacing but the raised pattern was just elongated blobs. UGH!
I may ask Plastruct if they will send CADD  ( DWG ) files for me to check as it appears I am just wasting money if I buy any diamond plate marked 1/24th scale.
    September 2005
Posted by Sprue-ce Goose on Sunday, January 15, 2012 4:59 PM
TheWildChild
Thanks for the tip.
Unfortunately, his website is closed due to illness and website restructuring.:
http://www.fredsresinworkshop.com/
    June 2008
Posted by Hans von Hammer on Monday, January 16, 2012 1:55 AM
*Sigh*... Buy this, buy that...
Get some screen and some foil, then burnish the foil down onto the screen...
Instant tread-plate...
Whistling
    March 2011
Posted by mike midnight on Monday, January 16, 2012 5:58 AM
i have one sheet left so i cant give it away,   but try Don Mills ,  models 25-1  tread plate, the plate is a little thick but the diamond pattern is to scale
    September 2005
Posted by Sprue-ce Goose on Monday, January 16, 2012 7:57 AM
Hans von Hammer
Whistling
Been thinking of methods to make the tread plate as well.
Very good idea, Hans, but the method doesn't sound as if it will make a diamond pattern tread plate.
I've tired making foil impressions of the small parts I have with diamond pattern tread plate and shifting the foil to enlarge the area of the impression.
Hard to get a neat overall effect.
I'll keep trying various methods while looking.
    September 2005
Posted by Sprue-ce Goose on Monday, January 16, 2012 8:02 AM
mike midnight
Thanks for the info.
Must be in demand by folks if sheets are sold at auction on Worthpoint .
Unfortunately, Diamond tread plate is not listed on his website and seem to have been discontinued.
    June 2008
Posted by Hans von Hammer on Monday, January 16, 2012 8:41 PM
Sprue-ce Goose
 Hans von Hammer:
Whistling
Isn't this diamond tread plate?
Actually "Diamond" and "tread" plate are redundant when used together, IIRC from my welding days... Wink
    September 2005
Posted by Sprue-ce Goose on Monday, January 16, 2012 8:49 PM
Hans von Hammer
 Sprue-ce Goose:
 Hans von Hammer:
Whistling
Isn't this diamond treadplate?
http://us.123rf.com/400wm/400/400/rustyphil/rustyphil0708/rustyphil070800277/1544228-a-very-large-sheet-of-cool-silver-or-stainless-steel-diamond-or-tread-plate.jpg
Yep !
However, my understanding of your description of burnishing foil onto a screen would seem to create this:
Confused
    September 2005
Posted by Sprue-ce Goose on Monday, January 16, 2012 8:51 PM
However, what I might do is glue a screen to a flat surface and trim away sections for the diamond plate pattern.
Then I could burnish foil onto that.Big Smile
.....if the glue welds the screen segments onto the base layer and those segments aren't torn off during trimming.
I'll give that method a try.
Appreciate the help !
    June 2008
Posted by Hans von Hammer on Monday, January 16, 2012 10:52 PM
Looks like that stuff was burnished onto plastic or fiberglass screen..  Wire screen is what I'm talking about, and it should give you a pretty good tread-plate pattern if the foil is lightly burnished... That way only the "top" of each wire is transferred to the foil..
    September 2005
Posted by Sprue-ce Goose on Monday, January 16, 2012 11:08 PM
Hans von Hammer
Gotcha !
Thanks for the clarification.
I will give it a try.
    December 2006
Posted by detailfreak on Monday, January 16, 2012 11:43 PM
                         I got some on E-Bay very cheap and it was said to be 1/35th but upon recieving it ,it looked more in the 1/24-1/25th scale. Techstar was the name on the packaging,let me find it and I'll shoot a pic or two next to a stainless rule.
[View:http://s172.photobucket.com/albums/w1/g-earl828/]  http://i158.photobucket.com/albums/t104/cycledupes/1000Roadwheels4BuildBadge.jpg
    December 2006
Posted by detailfreak on Tuesday, January 17, 2012 12:04 AM
                           II'mmm Baaacck.LOL Always liked sayin that. Heres the stuff.
                           If you can reproduce it as HVH  thinks great please share it with all of us.Great idea HVH,even with one piece of the stuff I have,it possibly could be reproduced for personal purposes just as you stated with the screen Hans.
                                                              Greg"Detailfreak"RowleyYes
                       Well gotta run the bigfoot hunters are in northern Mn. and I'll be darned if there aint a bit of a commotion outside right now, cripes its them theyve found me.LOL
    September 2005
Posted by Sprue-ce Goose on Tuesday, January 17, 2012 7:09 AM
Thanks for the photos.
Product looks good.
I did find this
Techstar Diamond Treadplate
but the nothing further so far regarding a manufacturer website.
I'll do a further search, but will try the method Hans described first as being able to produce my own parts would be far more useful ; I am not dependant upon an uncertain supply.
Unfortunately, my digital camera doesn't do very good macro photography so I'd post a description of my results.
Post again when ya get free of those Bigfoot hunters ...........Big Smile
    December 2006
Posted by detailfreak on Tuesday, January 17, 2012 10:00 AM
                                   That was close.LOL After my best search on evil-bay alas I could not find anyone selling Techstar treadplate.PM you.
    September 2005
Posted by Sprue-ce Goose on Tuesday, January 17, 2012 10:20 AM
detailfreak
Did you check that link I posted?
The product looks kinda similar, but the photo doesn't give as close a view.
    September 2005
Posted by Sprue-ce Goose on Tuesday, January 17, 2012 11:01 AM
I just tried the foil burnishing method advocated by Hans von Hammer.
The result looks like the proper size pattern and I'm satisfied that I can use the method to create realistic looking diamond tread for my projects.
Thanks again, Hans!Big SmileCool
    June 2008
Posted by Hans von Hammer on Friday, January 27, 2012 2:06 PM
No sweat...
Just a little "Old School"...Wink
