Micro Flat not flat?
    March 2010
Posted by Scorpiomikey on Tuesday, April 10, 2012 3:51 PM
Couldn't figure out where to put this, so it goes here.
Just finished the markings on my wildcat, and started painting over the gloss with Micromark Micro Flat to make it all pretty and pro looking. But whats this? my micro flat is not flat, but satin...what am i doing wrong?
Cheers.
Mike.
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    January 2009
Posted by fermis on Tuesday, April 10, 2012 10:45 PM
Try spraying from a little bit further away from the model, so the "flat" hits the model semi-dry.
Maybe even a little less thinner in the mix???Tongue Tied
    March 2010
Posted by Scorpiomikey on Tuesday, April 10, 2012 11:38 PM
I brush paint, maybe thats my problem. Is there a matt coat that works well with brushes?
My signature
    January 2009
Posted by fermis on Tuesday, April 10, 2012 11:52 PM
Ah, that puts a whole new paint job on things! (nyuk nyuk nyuk)
Have you tried Testors "Dullcoat" rattlecans? They work quite well. The only luck I've had with brushing flat/clear is in tiny spots, like a shiney CA spot.....larger areas result in a satin sheen.
    March 2010
Posted by Scorpiomikey on Wednesday, April 11, 2012 1:13 AM
Might have to try that, thanks fermis
My signature
