Anybody have any insights?
They have the X/YB-35 flying wing from Italeri in 1/72 listed for $53 USD! Cheaper than Ebay.
It is listed as "in Stock" which from previous posts should be OK.
Is it good to order?
thanks
On the workbench:
Trumpeter 148 MiG -21F
Yes, as long as it says in stock. I've ordered from them before using Paypal and its pretty fast order processing/ shipping.
Mike you are getting it for good price, got mine for $63
Their okay,I have ordered with no problems
Dang, I can remember those kits being dirt cheap in the 90s when AMT was dumping them; like $9.99 or less.
Rob Gronovius Dang, I can remember those kits being dirt cheap in the 90s when AMT was dumping them; like $9.99 or less.
From what I understand, the Italeri offering is superior to the AMT/ERTL kits.
mike_espo Rob Gronovius: Dang, I can remember those kits being dirt cheap in the 90s when AMT was dumping them; like $9.99 or less. From what I understand, the Italeri offering is superior to the AMT/ERTL kits.
They are the same kits.
http://www.cybermodeler.com/hobby/kits/it/kit_it_1280.shtml
Rob , look at the Pros and cons on the link you gave me.....says: "better than original"
Because of the type of styrene they used. AMT/Ertl had a bad habit of using really soft plastic that would mar if you stared at it too hard. Italeri uses better quality styrene.
Although if you used $5 worth of brass tubing and some 5 minute epoxy to strengthen the wings, it would eliminate the droop the AMT kits got over time.
Bottom line, they are the same molds, just 15 years older and three times the cost.
Oh. Was hoping that the newer kit had greater detail......
