Aves Apoxie Sculpt
    February 2011
Aves Apoxie Sculpt
Posted by 40kminis on Sunday, July 29, 2012 9:28 AM
I have been researching the best way to fill gaps on models and Aves Apoxie Sculpt came up. Seems like a lot of modelers use it.
I wanted to get feedback on it. For those that have used it, do you recommend it for a good way to fill gaps? Is it easy to use?
Also, not sure if color matters, but if so, what color would you suggest is best for plastic grey models?
    March 2010
Posted by Jerome Morris on Sunday, July 29, 2012 9:57 AM
I've used it a number of times. It comes in grey as well. it's  water soluble so very easy to work with.
Posted by Don Stauffer on Sunday, July 29, 2012 11:06 AM
If the gap is too large for normal putty to work, I fill the area with a piece of styrene or wood before any putty.  As far as color, I prime my work before painting, so the color of the putty is not an issue.
    August 2006
Posted by K-dawg on Tuesday, August 7, 2012 7:50 PM
Yup, love the Aves! Worked a treat filling the rather large hole inside an Academy F-86 intake. I used brass tubing and water to smooth it out...
Kenneth Childres, Central Arkansas Scale Modelers
