Paint Mixing
    June 2011
Paint Mixing
Posted by Redbird74 on Wednesday, August 29, 2012 4:48 PM
Can anybody help me with tips on how to transfer paint ( eg. Humbrol tins ) to my airbrush/ mixing container.
I always make a mess and never get the correct ratio.
I try and use syinges but have trouble with them
Please someone help!!!
Life is a highwayAutomobile
    June 2010
Posted by DoogsATX on Wednesday, August 29, 2012 4:54 PM
Buy some disposable pipettes. TPC Global sells them by the hundred load and they've got little tick marks so you can more-or-less measure. Some paints are easy to flush so you can use a pipette again and again until it fails, where others are more one-and-done.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
Posted by Bish on Wednesday, August 29, 2012 5:49 PM
I just use an old paintbrush, add a little at a time to the thinner until i am happy.
Posted by Wingman_kz on Wednesday, August 29, 2012 8:20 PM
Straws and coffee stirrers
    April 2009
Posted by bushman32 on Wednesday, August 29, 2012 8:27 PM
I use glass eyedroppers I got from Walgreens, in the eye/ears section.
Ron Wilkinson
Posted by Don Stauffer on Thursday, August 30, 2012 9:17 AM
I found whatever I used, I had to clean it, so finally decided to just pour from paint bottle into airbrush bottle. Okay, I have to clean the threads of the bottle, but as I say, whatever I did, I had to clean something.  Same thing with thinner.
I find thinning ratio does not need to be exact to three significant figures. If it is too thick add thinner, too thin add some more paint. I can make some adjustment for varying thinning ratios with airbrush adjustments and pressure.
I would say there is no exact correct ratio, merely a range of ratios that work.  You'll find with time that you learn to adjust your technique a bit with different thinning ratios.  Also, sometimes different thinning ratios give a slightly different finish so I sometimes alter the thinning ratio for that reason.  For example, to get a good gloss finish, the final coat should be a little thinner than the coats building up the finish.
    January 2009
Posted by Griffin on Thursday, August 30, 2012 9:25 AM
I use a plastic eye dropper from some of my kids' Tylenol. Rinse it out and re-use until it's beyond cleaning.
    April 2009
Posted by Cadet Chuck on Thursday, August 30, 2012 10:53 AM
I have found the pipettes to be the easiest and neatest to use.  You can usually find them hanging in a bubble pack of 5 from Testors at any hobby shop.  But buying in bulk quantities as mentioned above is a lot cheaper.  Just like clamps, you can never have too many!
    June 2010
Posted by DoogsATX on Thursday, August 30, 2012 11:19 AM
Also if you are being lazy and pouring straight from the bottle, a toothpick (or piece of styrene rod or whatever)  held against the lid will keep the paint heading down instead of potentially getting into the threading.
Posted by Wingman_kz on Thursday, August 30, 2012 11:52 PM
Don Stauffer
That's the nice thing about straws and stirrers, use them and toss them. Straws in particular are way long so I take a Sharpie and mark the ends then cut them in half with scissors. I mark them first because when you cut you don't always end up with a straight edge and your finger tip may not seal it. If there's enough straw/stirrer left clean to use it again I snip the dirty end off and reuse the rest.
Biggest reason is, I don't have to worry with cleaning. Secondary reason is, if I'm doing a lot of painting with several colors it's pretty economical. Although these days you do have to buy the better brands of straws because the cheap one's are too flimsy.
If you prefer to use pipettes but don't want to order them then stop by a local gun shop and see if they have them in their cleaning supplies. You can get 10 for less than the price of 5 Testors and they're basically the same thing. At least you can around here. I do use them for adding thinner because you have more control. And you don't have to clean them...
Tony
Posted by Don Stauffer on Friday, August 31, 2012 9:25 AM
Wingman_kz
Don Stauffer
Tony
I do use the coffee stirrers that are simple hollow cylinders.  Always keep some on hand. I use them primarily for mixing paint, but if I am just adding a small amount of a different color I do use them to transfer paint.  But those are too slow for the main color- too many dips.
    June 2011
Posted by Redbird74 on Friday, August 31, 2012 5:59 PM
Thanks all for your help everyone, great ideas!
