Stubborn chrome plating
    January 2013
Posted by BU2B on Sunday, March 24, 2013 10:06 PM
I can usually remove chrome plating with an overnight soak in bleach. However, I've had this particular part soaking for about 3 days and the plating is still holding on tight. Anyone ever run into stubborn plating like this before? any suggestions for removing it? A plan "B"...
If you choose not to decide, you still have made a choice....
    January 2003
Posted by TomZ2 on Sunday, March 24, 2013 11:30 PM
Plan B:
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    January 2006
Posted by dirkpitt77 on Monday, March 25, 2013 12:11 AM
I have found that bleach will get old, or stale if it's old stuff you're using. I encountered this same problem and when I bought a fresh bottle of bleach, the chrome came right off.
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
Posted by Don Stauffer on Monday, March 25, 2013 8:59 AM
If you want to remove it to just paint over it, a good primer will adhere to plating, so you don't really need to remove it.
    November 2012
Posted by kenposan on Monday, March 25, 2013 12:14 PM
Plan B by Tom should be Plan A. I have had horrible results with bleach and even tried the Coke idea. Nothing works like Easy Off in the Yellow Can. Don't know why, but it has to be the Yellow Can.
    January 2007
Posted by the doog on Monday, March 25, 2013 7:17 PM
What dirk and Don said---try a new bottle of bleach, and if that doesn't work, just prime it over and paint it. I've done it many times.
    January 2013
Posted by BU2B on Monday, March 25, 2013 10:32 PM
Thanx for all of the input guys.
I have noticed that after a couple of uses, the bleach does seem to lose it "pizzazz" and changing to some new really seems to remove the chrome much better. However, this time, changing to new bleach had no effect on the grill in question. So, before reaching for my Easy-off, I cleaned, primed and painted over the grill as recommended. Seems like it's got a pretty good "bite". We'll see.
I have since dropped some other plated parts into my bleach and the plating melted away in no time at all. Must have been some super adhesion of the chrome on this particular piece.
Thanx again for the advise
    April 2013
Posted by Digital_Cowboy on Saturday, April 13, 2013 9:02 AM
     Can either the bleach or Easy-Off method be used with enough precision so as to remove just a small amount of chrome plating to aid in gluing?
Digital Cowboy
Live Long and Prosper
On the Bench: '64 Ford Fairlane; '09 Corvette Coupe
