Most useless modelling tool ?
    January 2006
Posted by Wirraway on Thursday, February 13, 2014 5:46 AM
IIRC, there was a discussion a few years back about your most invaluable tool.  I think sprue cutters won the day.  What about your most useless/least used tool ?  For me, it was one of those "magic hands" thingies (you know the adjustable arm with a bulldog clamp at either end, sits on a weighted base)  Saw it at a model show and thought "hey I dont have one of these"  Sat on my bench (unused) ever since.    What impulse buy now mocks you every time you look at it ?  Or what did you buy with high hopes but were ultimately disappointed ?
"Growing old is inevitable; growing up is optional"
" A hobby should pass the time - not fill it"  -Norman Bates
GIF animations generator gifup.com
    September 2011
Posted by falconmod on Thursday, February 13, 2014 8:33 AM
Ya know I had the same one sitting on my work bench for years too.  But it came to the rescue when I was rigging my WWI Albatros,  couldn't have done it with out it!
Now one that is totally useless,   I think the most disappointing one is a line scribe I got that works like crap.  can't remember who it was from though.
John
On the Bench: 1/72 Ki-67, 1/48 T-38
1/144 AC-130, 1/72 AV-8A Harrier
    June 2013
Posted by rjhansen26 on Thursday, February 13, 2014 9:01 AM
Yup, I have one of those gathering dust on my bench also. I went all out and bought the one with the magnifying glass.
Roger
"Life is short..........Always eat dessert first!"
    October 2012
Posted by Geezer on Thursday, February 13, 2014 9:09 AM
Agreed. I am not sure where the magnifier is and the base with the "hands" is sitting out on my old bench that was replaced. A gentleman on another forum has a board with 40-50 holes drilled in it to hole what looks to be coat hanger wire or 12 ga wire - he has alligator clamps on them and can use as many or few as needed and the wire bends as needed, to.
Next would maybe be my hands.......
www.spamodeler.com/forum/index.php
Mediocraties - my favorite Greek model builder.
    April 2009
Posted by Cadet Chuck on Thursday, February 13, 2014 9:52 AM
"Touch 'N Flow" glass tube solvent applicator.
    April 2013
Posted by minimagneto on Thursday, February 13, 2014 3:00 PM
I have a helping hands, It comes in handy for soldering, never for modelling.  An optivisor may be a different story been thinking one of those might be my next investment.
My non-variable speed basic Dremel tool WAS considered useless (for plastic) until a buddy came over and pointed out that I could rig a dimmer switch to the power source and convert it into a variable speed. That fixed that.
My ball peen hammer is useful for builds gone terribly awry :)
I've used Testors lacquer clear coats to ruin more paint and decal jobs than I'd care to admit, I'll say that!
-Blake
    January 2012
Posted by Cdn Colin on Thursday, February 13, 2014 3:40 PM
Me.
I actually use my "magic hands" thing all the time.
I build 1/48 scale WW2 fighters.
Have fun.
    March 2005
Posted by TarnShip on Thursday, February 13, 2014 5:37 PM
propellant cans for Air Brush or Basic Spray Gun use
it doesn't take a person too long using those to realize that even the "wrong" air compressor is a better option than those cans
Rex
almost gone
    November 2003
Posted by mississippivol on Thursday, February 13, 2014 6:01 PM
Got a photo etching set for Christmas one year. Just never had the guts to make it work.
    November 2008
Posted by plasticjunkie on Thursday, February 13, 2014 6:15 PM
Wirraway
Really? I find mine extremely useful and own several that I have picked up from Harbor Freight for a couple of bucks each. I use them for attaching antenna wires, holding parts at awkward angles while the glue sets, propped up against a part to be glued at a difficult area to reach, rigging WWI planes, just to name a few. All my tools get used, some more than others but eventually they get used.
 GIFMaker.org_jy_Ayj_O
    November 2008
Posted by plasticjunkie on Thursday, February 13, 2014 6:25 PM
Cadet Chuck
I felt the same way until the company rep. showed me at the IPMS Nationals how to use it. Very simple:
Do not follow the directions on the enclosed literature but put the applicator needle end into the Plast I Weld bottle , then take the small plastic bottle with the blue cap and carefully insert it into the glass end, now slowly squeeze and bubbles will be seen out of the needle end in the bottle, release and the suction will load the applicator. Carefully slip out the plastic bottle and you are ready to weld. Keep the applicator horizontal to stop the flow and vertical to apply. If the tip get clogged just stick it back into the glue bottle and the glue will clear the clog by itself. Works like a charm and now I use it for just about every gluing situation.
    December 2004
Posted by panzerpilot on Thursday, February 13, 2014 7:04 PM
My Scriber. Perhaps it's operator error, but I can never scribe anything that remotely resembles a panel line with it. It does give me more practice with putty, however.
-Tom
    April 2009
Posted by Cadet Chuck on Thursday, February 13, 2014 7:19 PM
You are correct, Plasticjunkie, that is the correct way to fill the Touch 'N Flow and I use that method.
 Roger putting the needle end in the bottle to melt any plastic blocking the tip- that works.  But I have also gotten tiny pieces of junk that had collected in the bottle into the tube.  It then clogs the needle from the inside end, and there is no way to fix that.  I have avoided further instances of that by removing the crud from the bottle by running it  through a coffee filter paper.  The stuff is so tiny you can't see it in there unless you use a magnifier light.  I suppose it is residue from dipping a brush in the bottle over time.
Also I have problems with static electricity pulling the drop of solvent away from where I am trying to deposit it, and ending on the surface of the model way off target.  It's a great tool when everything is working just right, but I spend too much time getting it that way.  I find a very fine paint brush works just as well.
    May 2009
Posted by Konigwolf13 on Thursday, February 13, 2014 7:49 PM
My most useless but used item, My hands they always stuff something up...
On a more serious note my most useless or least used item? Would have to be my magnifying goggle things. They are just painful on my eyes to use to focus that close and my eyes are good enough (at the moment) that I don't need them anyways. Otherwise I'm cheap enough that I only buy tools I know I'm going to use a lot.
    November 2008
Posted by plasticjunkie on Friday, February 14, 2014 8:16 AM
Chuck
I have those pesky little particles too so I let them settle to the bottom and draw the glue near the top as the level gets low.
    August 2008
Posted by tankerbuilder on Friday, February 14, 2014 8:40 AM
Hi :
I believe at the moment I have only one really little used tool .Sad to say it's not cheap either .I bought it at an I.P.M.S. show , It's a P.E. bending tool .Steel and wood pins , baseplates of grooved and slotted aluminum and lexan . I find myself going to my first tools for that .A pair of Grozier pliers and a pair of duck billed Flat jaw pliers , used in the stained glass hobby and modified by me for P.E. ! and a regular flat pair of needlenose and a couple of different sized pen barrels .Quicker and cheaper  ! I think I paid $ 42.00 bucks for that bending tool too !
    August 2004
Posted by cwalker3 on Saturday, February 15, 2014 12:24 PM
My Optivisor is something that gets no use. Since I discovered the cheap reading glasses available at Dollar General I've switched to them and find them much easier to use. And since I wear glasses anyway, they are something that I've already gotten used to wearing.
Cary
    April 2004
Posted by Jon_a_its on Saturday, February 15, 2014 1:20 PM
A PE bending tool, the one with 'E' shaped clamp & plastic razor blades... Never Used it...
Borrowed a magnifier on a stand, with a built in light.... gave it back as not any use (to me anyway)
Useful tools... Lightweight 'optivisor style' magnifier,  & a good lighting rig...
6 Halogen Spots on the ceiling, 2 daylight bulbs on anglepoise lamps, 2 mini-strip-lights on mutipoise stands, 2 more high spots over the a/b station...
Is that too much? Cool
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    February 2006
Posted by ruddratt on Saturday, February 15, 2014 4:23 PM
Nice to see the support for the magic hands. Those of us who build WWI know what a valuable tool it really is.
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
Posted by Bish on Saturday, February 15, 2014 5:03 PM
I had one of those holding hands with a Magnifying glass. I just didn't like it as I could never get the part in the right place and the magnifying glass was always in the way when I was painting.
Of the tools I have now, there two I don't use. One is the touch and flow. Just seems to much hassle to load it up, I am still using an old fine paintbrush.
The other is an Etch Mate 3C PE bending tool. But that might come in useful for larger PE on armour, for small PE I find my flat nose pliers perfect and less hassle.
    November 2008
Posted by plasticjunkie on Saturday, February 15, 2014 5:22 PM
Bish
I posted this in the previous page and maybe you missed it:
" I felt the same way until the company rep. showed me at the IPMS Nationals how to use it. Very simple:
Do not follow the directions on the enclosed literature but put the applicator needle end into the Plast I Weld bottle , then take the small plastic bottle with the blue cap and carefully insert it into the glass end, now slowly squeeze and bubbles will be seen out of the needle end in the bottle, release and the suction will load the applicator. Carefully slip out the plastic bottle and you are ready to weld. Keep the applicator horizontal to stop the flow and vertical to apply. If the tip get clogged just stick it back into the glue bottle and the glue will clear the clog by itself. Works like a charm and now I use it for just about every gluing situation."
Works every time Bish, give it a try.
Posted by Bish on Saturday, February 15, 2014 6:40 PM
Ye, I saw that PJ, I will give that a try. I guess I am being lazy as it just seems easier to use a brush than load up the applicator.
    November 2008
Posted by plasticjunkie on Saturday, February 15, 2014 8:25 PM
Bish
I had two applicators and gave one away to a friend. I was getting ready to toss the one I had until I met the company rep at the Nationals who  showed me his method. I tried it and made a believer out of me. When the needle clogs place it back in the bottle and the glue clears the clog. You will eventually get a bunch of tiny junk which you can let settle to the bottom or strain the glue thru a paper coffee filter in to another glass jar, then dump the strained glue back to the original bottle. You only have to do this maybe twice.
