I only use CA cement for joining PE parts to plastic, as it is the only thing that will work. I don't use it for glueing poly plastic parts as is is messy, will run and mar your surfaces, and of course, glue your fingers together quite easily.
I recommend a solvent, such as Tamiya Thin Cement, Plasti-Weld, or Tenax. I hold the parts in position and just touch a brush of solvent to the seam, and like magic, capillary action draws it into the joint and in a few seconds, it's done nicely with no mess. I never use the stuff in tubes, as it tends to give you stringy things that will mess up the surfaces of your parts.
