Losing the battle tonight with my airbrush and AK Interactive Matte Varnish #775 (ACRYLIC)
Hello all, Mods feel free to move this if need be, but this forum gets the most traffic.... I lost the battle tonight trying to spray some AK interactive acrylic "matte varnish #775, I shook the bejesus out of it, and added to airbrush with a tad of AK interactive #712 "Acrylic thinner". I was spraying out of my new Paasche Talon airbrush with mt Paasche D3000R compressor. After a short gander on AK interactive's website, I could not find the recommended pressures to spray said matte clear. So I started around 22 psi, and it sprayed ok for a few seconds, then clogged. I for a couple times after that, I could put my finger over the needle, and "backflush" into the color cup, and get it working for a couple more seconds, then it just flat-out clogged. I emptied the cup, tore the airbrush apart, (basic disassemble) put it back toghether, then tried 30 psi, thinkinmg maybe I wasnt high enough on the pressure for the clear. Same results, Then, it started bubbling around the trigger when I tried to "backflush" it, and then I beleive the clear stuck the air valve OPEN. I took the airbrush apart, soaked everythibng in acrylic thinner, same result. Would work breifly, then reclogged, then the air valve stuck. Since I am new to airbrushing, I have some questions and will take any other feedback you have to offer. This was my FIRST attempt at using acrylic clear, not so good results. The brass allen setup on the bottom of the air valve is garbage, I must say. It stripped out pretty quickly, and I had to destroy the chrome plating on the air valve body to get the bottom off to get access to the valve and spring. It leaked air after reassembly of these parts at the bottom, closest to the air supply. This airbrush is only 4 months old, and this is my third or fourth use.
1. Is "back-flushing" in this manner BAD for the airbrush, or did it contribute to the airvalve clogging? (I will guess yes, since it seemed to get the clear into where it wasnt supposed to be?)
2. If you have used these AK interactive products, what kind of PSI did you use, or what results did you have?
3. WHAT ELSE can be used to clean up airbrush and related parts after acrylics other than water, and the $9/bottle /60ML acrylic thinner?
3 should spraying acrylic matte clear be this much of a PITA? I got my butt whipped tonight....
I was trying to finish this 1:48 PBY Catalina as a gift for my barber whose father served as a crew cheif on one in the pacific, as a sub-hunter.....I want to get started on my 1:48 B-29 superfortress for the Boeing GB!
THANK YOU for your help!!
RUDY
