Cheaper paint for weathering?
    April 2015
Posted by RudyOnWheels on Friday, August 14, 2015 3:17 PM
Hello all, I use Model Master (and testor's little bottles) paints pretty much exclusively. While I have used enamels mostly in the past, I am phasing them out in favor of the easier to clean up and faster drying Acrylics, also MM. At $3.99 a bottle, I am slowly acquiring a selection, but strictly for the purpose of weathering (which I am just beginning to attempt) can cheaper "craft store" paints possibly be used? Any other suggestions? My (somewhat local) HS carries Tamiya, humbrol, and some poly scale paints, none of which I have tried. They are no cheaper, often more expensive. Any ideas? Or do I just have to pay the piper.....?
  Thanks!
  Rudy
Posted by Tojo72 on Friday, August 14, 2015 3:19 PM
What do you mean by weathering ?
    November 2008
Posted by plasticjunkie on Friday, August 14, 2015 3:42 PM
Weathering is accomplished by using pigments, washes, filters etc. The same paint used as a top coat can be used in a fading effect by adding a few drops of a lighter shade to dial down the tone.
Craft paints are very affordable but I have found that a solvent type primer needs to be used for the craft paint to properly "bite" into the surface, otherwise it has a tendency to lift when masking tape is removed. Some folks use them but I'm personally not a fan of any acrylic.
 GIFMaker.org_jy_Ayj_O
Posted by Don Stauffer on Saturday, August 15, 2015 8:43 AM
The amount of paint used in weathering is usually pretty minimal.  Even the main paint pales in contrast to the cost of kits these days.  I think it is false economy to worry about trying to save money on paints, especially those used in weathering.
    September 2012
Posted by GMorrison on Saturday, August 15, 2015 9:30 AM
I agree with Don. After all the hours of assembly. But for washes and filters, I have a set of "beginner" oil artist paints, I think it was $ 18.00 for ten tubes of the usual suspects. I use those thinned way down with Turpenoid over a clear coat of Future and I like the results.
    November 2008
Posted by plasticjunkie on Saturday, August 15, 2015 11:27 AM
For washes I have a Reeves artist Oil Paint set that I grabbed at Hobby Lobby a while back with a 40% coupon that came out to under $15 and having about 20 tubes. I can make just about any wash color using turpentine.
    December 2011
Posted by Chrisk-k on Saturday, August 15, 2015 11:59 AM
Compared to kits, paints are dirt cheap.  Plus, you'll use an iota of paint for weathering.  Buy some earth tone oil colors and pigments, and they'll last forever.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
Posted by Don Stauffer on Sunday, August 16, 2015 10:38 AM
Remember, a wash uses an extremely thin paint mixture.  In drybrushing you are putting almost no paint on the brush, so either of these two weathering techniques are very sparing of paint.
    April 2015
Posted by RudyOnWheels on Monday, August 17, 2015 10:57 AM
Ok thanks guys. I figured it was probably a waste to worry about this aspect. I have had issues with my MM acrylics coming up with both blue painters tape or tamiya tape when applied directly to the plastic. I think it may have even pulled up the primer AND the acrylic paint one time..... I just had this happen after I taped off around the rear beds on a B-29 I am working on, and detail/brush painted them, then the tape took the green chromate paint off that was the base, and some of the other two colors nearest the tape. Seems like a PITA to have to prime EVERYTHING... But it may have to be the way its done with these acrylics.
Thanks for the help and input everyone....  Rudy
    April 2006
Posted by waynec on Monday, August 17, 2015 11:22 AM
i prime everything, usually with ACE Hardware NOW and never had a lift off with any acrylics including Vallejo using painters tape or silly putty. i weather with ComArt acrylics,  acrylic washes, oils, powders, pastels, real dirt and charcoal ash. artist oils are inexpensive; get the medium grade and look for craft store sales and coupons.
 one thing i rarely do is put a barrier between my paint and washes; no future, no flat coays, and have not had a problem with removing paint.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    August 2008
Posted by tankerbuilder on Monday, August 17, 2015 11:30 AM
  Rudy;
   I have used all the different paints there is I think . From M.M. to Oils , Acrylics etc .The cost is minimal . And , you don't really have to change Unless you want to .
It all works well And , it's the most minimal when used for weathering . I have a wash I made over a span of two years and I still have over half left .      T.B.
    July 2015
Posted by CheesyMeatBurrito on Monday, August 17, 2015 11:31 AM
I will never understand why people will risk cheaping out on a kit they spend money and hours on. Supplies are a small investment. People will buy more kits than they will ever build but wont spend on supplies.
 I'd recommend MM enamels to do your washes. Just thin them out when you need them. One bottle will last a long time. I don't like oils because they take forever to dry and cheap artist oils (the offbrands at Hobby Lobby like Thomas Kinkade) will cause problems with fogging and never completely drying.
    April 2015
Posted by RudyOnWheels on Monday, August 17, 2015 1:19 PM
Thanks guys. I forgot how long the Oils take to dry.... Wayne I am surprised you do not use a barrier before your washes, seems like SOP for most folks... I am learning as of now, so I don't have a great deal of experience with washes and whatnot. The only experience I have is with using some Valejo pre-made wash, I over-applied it thinking I could wipe it off, or at least get it to come off with a Q-tip and some acrylic thinner, NOPE! Rudy
    November 2008
Posted by plasticjunkie on Wednesday, August 19, 2015 8:15 PM
RudyOnWheels
That is one of the many things I like about oils. You can apply your wash, let it dry and come back the next day and fine tune things. Try doing that with Vallejo washes that dry super fast and are a pain to remove (if not done sooner). I used some Vallejo black wash diluted with water over NMF and let it sit for about an hour or two. It was a PITA to remove the excess which left traces of the wash on the wing. An oil wash would have come right off with a damp Qtip and thinner.
    November 2008
Posted by plasticjunkie on Wednesday, August 19, 2015 8:21 PM
CheesyMeatBurrito
The only time I have seen oils do that fogging or hazing effect is when they were applied too heavy in color and not enough thinner, specially the lighter colors like yellow ochre. A wash is tinted thinner, not thinned paint.
    December 2011
Posted by Chrisk-k on Wednesday, August 19, 2015 8:34 PM
Oil washes completely dry within 48 hours if you remove some linseed oil from oil colors or use MIG oil colors.  Works perfect for me.  Due to their slow drying time, I never screw up oil washes.  It's so easy to fine-tune details or correct errors.
    April 2015
Posted by RudyOnWheels on Thursday, August 20, 2015 12:13 PM
What do you thin the oil washes with? Regular hardware store lacquer thinner?
Thanks!
Rudy
    August 2015
Posted by crown r n7 on Thursday, August 20, 2015 2:26 PM
I use  turpentine for the oil wash and I also use  pastel chalks on a gloss finish
 Nick.
    November 2008
Posted by plasticjunkie on Thursday, August 20, 2015 3:33 PM
RudyOnWheels
Thanks!
Rudy
Do Not use LT! It will dissolve your freshly painted finish. I use this turp from Home Depot/Lowes.
    April 2015
Posted by RudyOnWheels on Friday, August 21, 2015 12:55 PM
Thanks guys!!! Sorry, I have no experience with turpentine. To be honest, until now I kinda put it in the same catergory as LT!!!! But I can see the LT eating the model alive!
  Thanks !
Rudy
    January 2007
Posted by the doog on Saturday, August 22, 2015 5:19 PM
Rudy, pleae see this page and post:
http://cs.finescale.com/fsm/modeling_subjects/f/3/t/164179.aspx?page=3
This is a tank that I weathered mostly with cheap craft store paints from AC Moore's. The kind that are like, $.99 cents a piece. The explanation of how I did it is in that post. You can DEFINITELY do impressive weathering with any old cheap paint if you experiment and learn from people who know how to do it.
Now painting acrylics over primer is also definitely a good idea, but not necessarily necessary if you're not going to be masking with tape over it. Model Master is notoriosuly fragile when masking; I would use Tamiya paint for that; it is actually an acrylic-lacquer blend, and it "bites" into the plastic more.
    August 2015
Posted by Miniworldly on Saturday, August 22, 2015 9:14 PM
You can save money by finding alternative thinners than the ones sold by the paint manufacturers
John Crumpton
