Decal sheet rolled around parts bag
    August 2013
Posted by Putsie on Friday, October 23, 2015 10:50 AM
Hi guys !  (and gals)
I've found one of the old Hasegawa F105's with the Thunderbird decals (1/72).
My next project is the whole series of a/c for both the Thunderbirds and the Blue Angles...have them all now.  (yes, I will include the "Sky Blazers"
The problem is that the decal sheet for the 105 was wrapped around the parts bag, apparently for a long time.  The sheet does not appear to be cracked but has quite a curve running the length....you could say 180.
Does anyone have experience with "flattening" a decal sheet ?  I don't want to ruin it.
I plan to scan it just in case some part of the decal "goofs" when applied.  That way I can make another.  I'm also thinking about using decal film as a just in case.  If necessary I could use the scanned copy for a "mask" for painting.  But I'd like to use the decals.
Any thoughts ?
Thx
    January 2012
Posted by Cdn Colin on Friday, October 23, 2015 12:03 PM
I don't think you'll have anything to worry about.  The decals themselves should not be curled; just the paper they're sitting on.  Once they come off the paper, they should flatten out.  After all, decals on a flat sheet curl readily around a fuselage and settle down.
I build 1/48 scale WW2 fighters.
Have fun.
    January 2013
Posted by BlackSheepTwoOneFour on Friday, October 23, 2015 2:34 PM
Stick it inside a book to flatten for a day or two.
    August 2005
Posted by Phil_H on Friday, October 23, 2015 11:02 PM
It shouldn't be a problem. However, if they're that old, I would consider coating them with somehitng like Microscale Liquid Decal film as insurance against the chance they may break up when immersed in water.
    September 2012
Posted by GMorrison on Saturday, October 24, 2015 3:22 PM
Should be just fine. In fact I would avoid flattening them out before you use them.
Liquid decal coat is a good idea. Just remember that you then have to cut them out right around the edges of the image.
    June 2010
Posted by OctaneOrange on Tuesday, October 27, 2015 8:40 PM
As GMorrison said, leave them curled and just cut them out and wet them when using. unfurling them may crack the decal.
    August 2013
Posted by Putsie on Wednesday, October 28, 2015 9:57 AM
thx
    August 2013
Posted by Putsie on Wednesday, October 28, 2015 9:58 AM
thx
good advice from everyone....
