panel lines
    April 2016
Posted by Stuburbia on Tuesday, May 31, 2016 3:07 PM
Ive been trying the testers wash fx ive tried both acrylic and enamel yes it beads but no matter how much i thin it it wont flow.
regards.
christopher stewart
    November 2008
Posted by plasticjunkie on Tuesday, May 31, 2016 3:07 PM
Try a pin wash. Use a fine brush loaded with the wash and touch the panel line. The wash should flow into the panel line.
 GIFMaker.org_jy_Ayj_O
Posted by Bish on Tuesday, May 31, 2016 3:13 PM
I am not familiar with testors wash, so forgive me. If's it acrylic, try adding a small drop of washing up liquid. It helps break the surface tension. I never have this problem with enamel washes, but flory wash can bead depending on what surface it is on. Its ok with Future, but not alclad or xtracolour enamel paint.
    April 2016
Posted by Stuburbia on Tuesday, May 31, 2016 3:39 PM
ive been trying the pin wash but still wont flow. if i thin my stuff anymore it willl just be thinner at this point lol.
regards.
christopher stewart
Posted by Bish on Tuesday, May 31, 2016 3:57 PM
Thinning won't help, in fact a pin wash is generally thicker than an over all wash. What ever surface you putting it on is repulsing your wash, and the thinner will just make it worse.
    April 2016
Posted by Stuburbia on Tuesday, May 31, 2016 4:02 PM
Ive used future as the gloss coat so any suggestions would be welcomed
regards.
christopher stewart
Posted by Bish on Tuesday, May 31, 2016 4:03 PM
Ok, well that answers one question. The second is the wash, you said its testors. Is that acrylic or enamel.
    April 2016
Posted by Stuburbia on Tuesday, May 31, 2016 4:07 PM
I know your supposed to use the opposite of the gloss coat so ive been useing enamel
regards.
christopher stewart
Posted by Bish on Tuesday, May 31, 2016 4:39 PM
Useing the opposite is only really impiortant when you have an enamel base as the thinner is very harsh, you can used water based wash on Acrylic base, but i often se the same issue. I have had thise problem on occasion when applying to future, i have found it hit and miss even when useing the same brand of wash. I take it you have tried useing the wash neat.
    April 2016
Posted by Stuburbia on Tuesday, May 31, 2016 4:59 PM
as i am kinda a newb (but have some skills) please describe a neat wash.
regards.
christopher stewart
Posted by Bish on Wednesday, June 1, 2016 12:47 AM
Without any thinner.
    January 2014
Posted by Silver on Wednesday, June 1, 2016 9:23 AM
you can do a dark acrylic sluge wash over the gloss on the panel lines.Brush on let dry , and gently wipe away.It will highlight the panel lines.Water a few drops of dish washing gel,the dark color.
