Hi,
I'vepicked up a couple new kits over the last month.
It will probably be awhile before I can get to any of them, but for the most part I hope to do up the Ark Royal, Mikasa, the Missile Launchers, and the P6E as-is mostly out of the box, but was maybe thinking of doctoring up the Hs-123A-1 as a what-if, and also maybe use the 1/800 Kitty Hawk hull and fittings as a starting point for a 1/700 scale what-if along the lines of some of the more recent new French Aircraft carrier concepts.
The Containership is something I bought on a whim, and it comes with an electric motor to play with in a pool, but in looking at it, it appears resinably accurate as a stright up 1/600 containership with a set of scale 40ft deck containers. As such I may try and add some detail and keep it along side some of my other 1/600 scale models. The only major changes I may make is adding a stern skeg for the centerline propeller, clean up some of the bits and chocks (they are a bit tall), and maybe try and add some railing, etc.
Pat
