How to get smooth seams on airplane wings?
    October 2017
Posted by Jay Bones on Sunday, October 29, 2017 1:35 AM
Hello all.  New member here, and I have a question regarding how to get smooth seams on airplane kits that have the wings in 2 pieces- upper and lower.
I've tried using glue along the edge, but excessive model glue softens the plastic and is hard to look real.
I've tried Bondo and clear silicone, thinking that spray paint would cover and not be noticeable.  Also tried brush painting, never with very good results.
    August 2014
Posted by goldhammer on Monday, October 30, 2017 12:11 PM
I usually use a couple of coats of liquid cement on both halves, then clamp tight to get a little squeeze out.  Let dry completely then scrape and sand to profile.  Any "gaps" left I fill with perfect plastic putty (PPP),wiping flush with damp q-tip before it dries.
If it lets go because I let dry too much before clamping, will wick in some Tamiya thin to reglue while clamped.
Gaps between wing root and fuselage can be more problematic, but can be filled with stretched sprue, thin styrene sheet, etc. then finished with putty.
Have pretty much gone to PPP for ease of use and non-shrinkage
Silicone is a no-no, you'll find paint, glue, and anything else won't stick to it, and is a royal pain to get it all off to do repairs.
    September 2012
Posted by GMorrison on Monday, October 30, 2017 12:17 PM
A trick that sometimes helps at the wing root is to glue the top halves to the sides of the fuselage before gluing on the bottom half.
    January 2014
Posted by Silver on Friday, November 3, 2017 9:15 PM
Make sure you get the gap leveled and straight.Sand the area lightly with a very fine sand paper then use “Perfect Plastic Putty “ .Apply it on the area then with a cotton swab wipe in a single straight motion.Let dry and sand lightly to smooth out.The product is on the internet .
    March 2015
Posted by Peaches on Sunday, November 5, 2017 8:35 PM
Personally I use Tenx-7r or plastic trim glue and just hold the parts together especially if it's a monobody construction.
WIP:
Academy F-18 (1/72)
On Deck
MH-60G 1:48 (Minicraft)
C-17 1/144
KC-135R 1/144
Academy F-18(1/72)
Ting Ting Ting, WTF is that....
