I have 2 on order and they should be with me in a week or so.
I will put up an in-box review as soon as I can.
My initial thoughts are, from seeing the pre-production sprues and build at telford last year is that it is going to be a really nice kit to build and should look good. THe only drawback I had and did discuss this with the kit designer was that cheap pale blue oily type plastic that airfix use.
"it keeps production costs down"
"It drives builders crazy and warps way too easilly which costs you in replacement parts!"
Still, if it is of the same engineering and design quality and detail that the Tiffy is, and it does look like it from what I saw then it will be a cracker of a kit.
Eduard already have a cockpit (interior) set, engine set, steel seatbelt set and two masking sets.
HGW are doing a seatbelt set
Top Notch have announced a US Masking set to match the decal sheet in the kit.
Master Models are, I think, doing replacement barrels for the .50's.
So, If you can hang tight for a while then I will give you a good look at the kit!
