F1 model - paint & coating procedure for finicky parts
    May 2020
Posted by ohms on Tuesday, May 12, 2020 2:08 AM
Revell F1 BMW Sauber
Hi guys,
Came into modelling in a serious way in the last few months. Will introduce myself properly on the introduction forum soon, but for now, I wanted to ask: what's your procedure for small, finicky parts that come together as a whole?
Take the front and back wings on the above model. It's the one I'm busy with. For the wings, which are made up of several parts, some parts of which require 2 colours, do you 1) put the entire wing together, then airbrush the different colours using masking tape, or do you 2) airbrush each piece first and then assemble?
I tried to colour the pieces entirely first and then assemble, but it was too difficult to get the entire structure to hold (maybe I should glue one piece at a time, or use superglue for such minute pieces). Also, because I tried so many times to re-connect the pieces, the glue damaged the paint, and the paint scratched off in places (will probably need to do multiple coats to prevent that next time).
And where does the gloss come in? Do you gloss each piece also before glueing, or build the entire wing and then airbrush the gloss? I'm guessing if you build the entire wing first, the gloss won't reach in certain places. So does that mean I gloss each little piece on both sides and then build? It's a lot of work, which I don't mind, but I just want to know if there's a shortcut. The YouTube videos usually skip these parts.
Will appreciate any and all help. Thanks in advance. Glad to join the community!
Tags: F1 , formula one , Wing , Wings
Into model building since September 2019. Also into books (mostly science-fiction), comic books, and gaming.
    July 2014
Posted by modelcrazy on Wednesday, May 13, 2020 7:44 AM
Hi Omes, I'm not a car modler but I believe I can answer this question.
Most of us assemble the pieces before adding them to, in your case, the car body. We will fill the gaps with a good filler, sand smooth, paint (after the entire kit is mostly assembled and masked off), spray gloss coat. Car guys can give you a better sequence of events for autos but the way in stated is usuall the way.
Steve
    May 2020
Posted by ohms on Wednesday, May 13, 2020 9:13 AM
Hi Steve,
Thanks for the reply.
I'm actually referring to how you would treat each tiny piece of the sub-assembly, like the wings or wishbone, before putting the sub-assembly itself together.
Actually, don't worry about the painting question. That was stupid on my part to ask. You can do it either way, I suppose: paint all pieces individually first, or paint with masking after putting it together.
I just want to know about the gloss. If you choose to paint all the pieces individually first, is there anyone who would actually then gloss EACH SINGLE PIECE, front and back, before glueing the subassembly together? Or do you put the sub-assembly together and then gloss as much as you can, hoping you get the little corners.
I've never seen anyone online do it the piece-by-piece way, which is why I'm asking. It seems more work than necessary.
    November 2003
Posted by bobbaily on Wednesday, May 13, 2020 10:36 AM
Hi Ohms and welcome.
I would suggest posting over in the Auto forum-some great builds & builders there that I'm sure can offer advice.
I don't do any F1 cars (yet) but on other builds, I paint the smaller pieces seperate (as much as possible), assemble and then gloss (or more often, dull coat-military planes and armor).
And please post pics
Bob
Bob
    May 2011
Posted by Real G on Wednesday, May 13, 2020 11:21 AM
For current F1 cars, I can’t think of any other way to do the spoilers except to paint, decal, and gloss the parts individually, then assemble.  They have that crazy “how many blades can you put in a disposable razor” look.  All of those little aero wings scattered over the body of the car would need to be addressed based on how they attach - if they need to be blended in, then obviously they have to be added prior to any paint.  But if they are just bolted on, they can be finished separately and added last.
That’s why I like 1970-1980 era F1 machines - so much simpler.
Oh, and welcome to the forum!
“Ya ya ya, unicorn papoi!”
    May 2020
Posted by ohms on Wednesday, May 13, 2020 11:49 AM
@bobbaily
Ya, sorry about that. I only noticed after posting that there are more specific threads beneath. Will post there next time. Smile
@Real G
Thanks, so that explains it. Each piece done basically completely before glueing. I sort of guessed this was the only way to do it, but I didn't want to waste the model before asking first. Looks like the modern F1 car is definitely a lot harder than the tanks I just finished! Stick out tongue
Thanks to everyone for their advice and warm welcome. Definitely going to be a regular visitor to these forums in the forseeable future. At 5 checks just today, I think I'm already hooked!
    May 2011
Posted by Real G on Wednesday, May 13, 2020 12:51 PM
But beware the super glue!  It can fog and thus spoil all your hard work!  I'd use either thick solvent glue or maybe a PVA type like Gator Glue.
I'm an F1 noob, but I think separate finishing is the way to go.
