Tamiya glue
    March 2020
Tamiya glue
Posted by Having-fun on Wednesday, August 19, 2020 9:58 PM
I have been using Tamiya glue (The one with the orange cap ) and I have notice that sometimes it does not glue the parts, some of the parts that I had glue they simple come off after a few hours.The area in question is not painted, was washed with soup and water and I have put sufficient amount of glue on the object being glue. Do I am doing something wrong or do I am applying the glue incorrectly? Is there a problem, with the Tamiya glue?
Thanks
Joe
PD The model being built is the Heller Le Solei Royal.
    August 2005
Posted by Phil_H on Thursday, August 20, 2020 12:19 AM
It's possible that you're not using the right technique in applying the cement. Like most liquid cements, Tamiya's orange (regular) and green (extra thin) capped cements are volatile solvents. Thsi means they "glue" parts together by solvent action melting the plastic slightly so that the parts adhere to each other (this is sometimes referred to as "solvent welding") If you brush the cement onto one part and press the parts together, often, the cement simply hasn't enough time to melt the plastic sufficiently and though the parts stick initially, they will quickly fall apart.
The best way to use liquid solvent type cements is to hold the parts together and apply the brush to the join between the parts. The close contact between the parts will draw the liquid cement into the joint and give the cement more "active time" between the parts to form a good bond.
Beware. Be sparing with the cement. As the cement flows along the joint easily via capillary action, it also flows along panel lines and ridges on the parts. Be aware of where your fingers are and watch out for any lines/ridges which may draw cement below your fingertips. Many a model/part has been ruined this way.
Good luck!
    July 2013
Posted by modelmaker66 on Thursday, August 20, 2020 1:46 AM
Phil, The orange Tamiya is too thick to apply via the capilary method. You put some on the parts and the bring them together. I have never heard of it not working though. Are you sure you aren't using resin or vinyl parts? It won't work on those. It should always work with styrene though.
    August 2005
Posted by Phil_H on Thursday, August 20, 2020 4:00 AM
modelmaker66
I hadn't realised that. I've used the white (thick) and the green (thin) Tamiya cements. For some reason I'd always assumed the orange was similar to the Testors "pink label" liquid cement. Having just checked the Tamiya "orange cap" (I have one, but haven't used it) it is indeed thicker than I thought.
In relation to the original problem, there's a number of possible things to consider (a) the type of plastic, as mentioned (b) the size of the contact area on the parts being glued (c) whether the parts being glued are load-bearing (d) age or possible contamination of the cement (e) surface contamination causing the cement not to stick
    July 2018
Posted by Tickmagnet on Thursday, August 20, 2020 6:03 AM
I use the Tamiya Orange cap cement and the Extra thin excluxively and they work great for me with the exception they both manage to occasionally leave their fingerprints on my models. I have no idea how they do that. ConfusedBig Smile
    June 2014
Posted by bluenote on Thursday, August 20, 2020 7:59 AM
the one with the orange cap is the limonene version, which I believe is not as strong as their regular glue (white cap).
I would buy a bottle of their white cap glue
Posted by Tojo72 on Thursday, August 20, 2020 8:15 AM
Tickmagnet
I usually use the green cap stuff,never looked at the orange.Your saying that stuff is used glue to pieces together as opposed to welding the pieces together as the green cap does.
If so I must get some could be useful too
    May 2013
Posted by Greg on Thursday, August 20, 2020 8:52 AM
modelmaker66
My thoughts exactly.
I've been using the orange cap for a year or so now, really like it for joins that aren't suited for the capillary action method, as already mentioned.
I do suppose if the jar is really, really old it may have expired. That's just a guess, I've not had a jar long enough for that to happen.
    October 2019
Posted by Tanker-Builder on Thursday, August 20, 2020 9:14 AM
Hi;
 Aha! the Heller Soliel Royale! Nice project. When I built mine, Many years ago, I used Testors liquid Cement. I now use the Tamiya green top for everything except Resin of course. I didn't know about the others. Never have seen them as a matter of fact!
     Now that said. If you aren't getting Capillary action it is because the glue is too thick to depend on this. A thin coat on both parts and then wait 30 seconds and then clamp should work. I remember when Tube glues were the only choice. The thinnest which was REVELL even said ,"Put a thin film on both parts let set for a few seconds and then fasten together ,clamping well."
     These Glues you mention, and that the others have mentioned I have again, Never seen or heard of. I have mostly in my years used the aforementioned Testors or Solvaset.
    April 2020
Posted by Eaglecash867 on Thursday, August 20, 2020 9:41 AM
The orange cap cement is great for situations where using the capillary method isn't an option.  I mostly use the green cap cement though.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    March 2020
Posted by Having-fun on Thursday, August 20, 2020 10:03 AM
As always, you guys come to the rescue!
The parts I am trying to glue are the canons in the lower deck, since the deck is not going to be seen, I did not prime it or painted it. I did wash both the canons (The canons base, since they are red and that is going to be finish color, I did not paint them either ) and the deck. I will be more careful when applying the glue and also will check out the white capped glue.
I was not aware of how the different types of glues worked, I will keep that in mind.
Thanks again
Joe
PD. I am running a tread called “My Royal built” were I go into detail on the construction of the ship.
    August 2005
Posted by Phil_H on Thursday, August 20, 2020 11:02 AM
bluenote
The orange capped 20ml in the hexagonal bottle (87012) is regular solvent based cement. The Limonene version is also orange capped, but comes in the larger 40ml square bottle and is clearly labelled as "Limonene"
    September 2012
Posted by GMorrison on Thursday, August 20, 2020 11:18 AM
Solvent glue needs a decent pair of mating surfaces.
    January 2015
Posted by PFJN on Thursday, August 20, 2020 1:00 PM
Having-fun
Thanks
Joe
Hi,
I sometimes use the Orange capped Tamiya glue, mostly with no problems, but I also sometimes will use Plastruct Plastiweld for other bonding glues in certin areas, especially if I am having trouble getting a prt to stick.
Pat
PS. he other hand I see in your initial post you are washing the parts with soup & water, so maybe the chicken noodles are getting in the way of a good bond Stick out tongue
1st Group BuildSP
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Thursday, August 20, 2020 1:46 PM
I've tried these "new" glues and didn't like the results.
New doesn't always mean better.
So I went back to the good ol' laquer thinner I've always used.
MUCH cheaper too.
 https://i.imgur.com/LjRRaV1.png
    March 2020
Posted by Having-fun on Thursday, August 20, 2020 9:13 PM
"PS. he other hand I see in your initial post you are washing the parts with soup & water, so maybe the chicken noodles are getting in the way of a good bond "
Hey, I was told that chicken soup would cure just about anything! LOL
Yes, sometimes I do misspell or use the wrong word because it sounds similar, in addition to be a lousy typist, ( I type at about 35 words per minutes, but commit 32 errors per minute ) obviously I was referring to soap.
Joe
Posted by Tojo72 on Friday, August 21, 2020 4:49 PM
I picked up some of the Orange Cap stuff,really love it.Not as a replacement for the Green Cap but it really worked well for my Sherman fenders,as was mentioned,its great for hulls,wings, and fuselages.
Great stuff thanks.Sometimes get a narrow focus and don't always see different stuff.
    October 2016
Posted by Mrchntmarine on Friday, August 21, 2020 5:28 PM
disastermaster
MUCH cheaper too.
just straight LT?
Keep on modeling!
All the best,
William
    October 2016
Posted by Mrchntmarine on Friday, August 21, 2020 5:32 PM
Ive got more glues than i probably need.  But i use model master glue in the black triangular bottle with the long neck.  Label on my new one reads Rustoleum.  Hope they didnt change the formula.
Keep on modeling!
All the best,
William
    July 2018
Posted by Tickmagnet on Tuesday, September 1, 2020 6:20 AM
Tojo72
Tickmagnet
The orange cap cement you spread on the parts then attach them. Not sure if it's welding them like the thin or not but it works well for parts I cannot or do not want to use capillary action on. It dries slower so you have time to work with it.
    April 2020
Posted by Eaglecash867 on Tuesday, September 1, 2020 7:59 AM
The Orange Cap stuff also welds the plastic together...just doesn't almost instantly evaporate like the green.
    May 2013
Posted by Greg on Tuesday, September 1, 2020 8:04 AM
It looks like this never got sorted.
This is baffling, the orange cap stuff is about as fool proof as possible, and as MM66 said, I've never heard of it not working, either.
Are the parts resin by any chance? Or nylon or anything other than styrene?
    October 2019
Posted by Tanker-Builder on Tuesday, September 1, 2020 8:12 AM
Hi Greg!
       Having Built this kit twice over the years,I can assure you there is no resin in this kit. However some Heller kits do take longer to react to some glues. I could NEVER get the Testors Tube Glue to stick on the first one. That's when I discovered the Liquid Cements!
     That said, I have come to the conclusion that Heller was NOT using Virgin Styrene. Even trace amounts of  any other type in that chain would elicit a different reaction. I have also had that problem with some Imaii Kits!
    August 2005
Posted by Phil_H on Tuesday, September 1, 2020 8:17 AM
Greg
I'm not sure if the OP is using the regular orange cap or the orange cap limonene. The regular orange cap, as I mentioned above, is 20ml and comes in a hexagonal jar. The limonene variety comes in a 40ml jar. If it is the limonene version, I can see it being not as strong (though I've never used it so I may be off-base)
On a related note, does anyone know if the 40ml white cap is the same cement as the 20ml orange cap?
    October 2016
Posted by Mrchntmarine on Tuesday, September 1, 2020 9:20 AM
a little off topic i think - but - whats good for resin parts?
Keep on modeling!
All the best,
William
    May 2013
Posted by Greg on Tuesday, September 1, 2020 9:28 AM
Tanker-Builder
Hi Greg!
Hey TB. That's an informative post, might clear up many things.
I was going to mention that the Testors Orange cap is about as close to tube glue as I've seen, and I'm not sure I agree with some posts here that is is just a thick solvent. I think it is filler and solvent, designed to fill gaps. I never quite understood how tube glue works in the first place, so I'm just guessing.
I haven't done a Heller kit since the 60's, so any peculiarities in the plastic are lost to memory.
Again, good post, thanks.
    January 2013
Posted by seastallion53 on Tuesday, September 1, 2020 9:35 AM
The white gasket in the lid of the tamiya glues falls out of the lid alot with me,anybody else?
    May 2013
Posted by Greg on Tuesday, September 1, 2020 9:37 AM
Phil_H
Greg
Ah, I looked up the limonene version and I see what you mean. Both 'orange caps. Thanks for elaborating, I understand your comment above better now.
I didn't even know about the limonene version. Took two posts to get through my thick skull, but you made it. Toast
    May 2013
Posted by Greg on Tuesday, September 1, 2020 9:43 AM
Mrchntmarine
I've always heard CA or epoxy.
I like to use CA gel with resin, and Bob Smith's IC-Gel is my preferred brand, FWIW. Nothing has fallen apart so far. Knock wood.
I don't have as much experience with resin as others here, so maybe there will be better advice to follow.
    September 2006
Posted by the Baron on Tuesday, September 1, 2020 10:22 AM
Tojo72
I usually use the green cap stuff,never looked at the orange.Your saying that stuff is used glue to pieces together as opposed to welding the pieces together as the green cap does...
If I may offer a clarification, both glues work by welding the pieces together.  The difference between the two is in thickness.
The one is thin enough that you can hold two pieces together-fuselage halves, say-and use the applicator to flow the glue into that seam, where it melts the plastic and forms the weld.
The other is a little thicker, and won't flow sufficiently, so you have to brush it on to the parts and then place them together.  The glue still melts the plastic and forms a weld.
Best regards,
Brad
