Space Ranger
What is "CF glue"? I'm not familiar with the term.
'CF' is typically used for 'carbon fiber'...though, given the context, it seems Joe meant CA.
I typically use those little 'lipstick' packs of Krazy Glue (with a smaller tube dispenser inside), and rarely have many of the troubles Joe quoted. The key is to keep the dispenser sitting upright in its little base when not in use -- I usually give the bottle a little 'tap' on the worktable first, to encourage any collected adhesive to run down away from the tip -- and wait a few seconds before putting the little 'plug' back in, to minimize chances of gluing the pin in place.
I can't say I've never gotten the glue on my fingers...since it's clear and pretty low-viscosity, it's not always easy to tell where it's gone...but I've never managed to glue fingertips together, or even come close. That suggests you're using way too much adhesive.
Like the others, I'll occasionally 'decant' a bit for a more precise application. I have a home-made 'precision applicator' -- literally a piece of wire glued into a toothpick 'handle' -- that works perfectly for tiny applications; it can be bent or curved as necessary to reach nearly anywhere. When too much has built up on the tip, just clip 1mm off the wire, and you've got a brand-new tip.
