This is beyond embarasing, but I have to share
    July 2008
Posted by castelnuovo on Saturday, March 20, 2021 12:30 AM
Just to get it off my chest. Please tell me I am not the only one who did this. I glued the bombs on backward Boo HooBoo HooBoo HooBang HeadBang HeadBang HeadCensored
It is not that visible here but once the rack is turned into its proper position it is visible.
Nooooo
    May 2011
Posted by Real G on Saturday, March 20, 2021 12:41 AM
Take a deep breath, and say "It's only a hobby.  It's only a hobby."  Then carefully remove the bombs, clean off the glue, do any paint touch up, then reattach the bombs the RIGHT way around.  The last part is very important!
“Ya ya ya, unicorn papoi!”
Posted by gregbale on Saturday, March 20, 2021 4:40 AM
castelnuovo
Nooooo
No more embarassing then getting main landing gear struts switched...and putting them on backwards.
I've...er...heard, that people have sometimes done that....
Whistling
["Now why won't these $!#@ doors fit!?!?...."]
Greg
George Lewis:
    April 2020
Posted by Eaglecash867 on Saturday, March 20, 2021 5:50 AM
Ahhh...yes.  Reminds me of the main gear on the F-16 I just finished.  I had to start from scratch on it no less than two times, where I screwed up so badly there was no choice but to get new sprues with the parts I needed.  Had at least two more times on the same thing where I had to soften plastic with more cement, pull things apart, glue them back together (in the CORRECT sequence this time...LOL).  It almost made me give up.  I'd be all happy, about ready to finally move past that step, and the "final" test fit would result in a "You gotta be s****in me!!!".  Heh...maybe I jinxed myself with the decals I selected for the project.  They were titled "50 Years of YGBSM".  Been there...done that...still designing the t-shirt.  If you haven't done it already, try a tiny bit of Tamiya Extra Thin at each joint between your bombs and the MERs.  Let it sit for a little bit, and then you should be able to carefully separate them with minimal damage.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
Posted by Tojo72 on Saturday, March 20, 2021 6:18 AM
I put my entire run of Panzer III tracks on backwards.
    October 2019
Posted by Tanker-Builder on Saturday, March 20, 2021 6:30 AM
Yah Whoo!
     I am Glad I am not the only one who does stuff like that! I've done that more times than I care to count. Especially with Foriegn built Aircraft!
    May 2013
Posted by Greg on Saturday, March 20, 2021 8:43 AM
Tanker-Builder
Well said, and I'd like to second that.
Ditto
Posted by Don Stauffer on Saturday, March 20, 2021 8:56 AM
If you used CA glue there is a CA debonder.  Many people do not know about this stuff.  Many hobby shops do carry it.l  Use as little as possible, and wipe up any excess afterwards, because it does weaken styrene.  Start pulling each joint apart as soon as you apply it to the joint and maintain the pull till the bond weakens and you can pull the joint apart. lt has saved my bacon many times.
    April 2020
Posted by Eaglecash867 on Saturday, March 20, 2021 9:11 AM
I forgot to mention this in my previous post, but be conscious of where your cement or debonder may end up running and make sure you put the parts that are easiest to strip and repaint, if you end up having to do so, in that location.  I know how demoralizing it would be if an accident ended up destroying the detail on those bombs that you put so much work into.
    September 2012
Posted by GMorrison on Saturday, March 20, 2021 10:19 AM
Don Stauffer
I, um, keep it close to my left hand.
    September 2004
Posted by tankboy51 on Saturday, March 20, 2021 10:21 AM
I just did that with  Pzkfw IV also.  Put one track on backwards.  And I was checking it before hand and I still did it.  Some times the brain is not working.
    December 2020
Posted by TheDemiGod on Saturday, March 20, 2021 11:27 AM
Oh boy... we all have made stupid mistakes from landing struts on back@$$wards, armor tracks backwards, doors on wrong side, just about any part installed wrong. You're not alone. LOL!!
    March 2010
Posted by mach71 on Saturday, March 20, 2021 12:18 PM
Rumor has it that I glued my 22 inch Space 1999 eagle CM to the mounting structure upside down...
Or that the launch tower rocket on my 1/12 Mercury was glued on rotated 60 degrees.
So don't feel bad, it's all part of the hobby.
    September 2015
Posted by Rookie104 on Saturday, March 20, 2021 12:31 PM
Good Information Don - wondered just how that de-bonding process would work!!
    May 2013
Posted by Greg on Saturday, March 20, 2021 1:06 PM
GMorrison
Smile
That's funny, that's where I keep mine too. I dislike CA a lot and use it as seldom as possible, but nonetheless the debonder never leaves it's special place on the bench.
Just in case....
    July 2004
Posted by stikpusher on Saturday, March 20, 2021 2:02 PM
Wait. Oh my! What have you done. I’m backwards. You flea-bitten furball! Only an overgrown mop-head like you would be stupid enough to…”
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    May 2011
Posted by Real G on Saturday, March 20, 2021 2:57 PM
stikpusher
Aw dang, I have done that.
I have also painted an entire model the wrong shade of dark yellow.  That's why I don't paint in the garage during the day anymore.  The shadows under the garage combined with the glare from the street blinded me.  I didn't see the problem until I took the model inside and turned on the desk lamp.
Posted by gregbale on Saturday, March 20, 2021 3:42 PM
Real G
Mine along that line was reaching for a spray-can of Dullcoat (no cap, white label) and instead mistakenly picking up (no cap, white label) Testors Gold.
Left my hitherto-nicely-desert-camouflaged Hasegawa 88mm...and full crew...looking far more festive [or C3PO-like] than Field Marshal Rommel would likely have tolerated.
Live and learn....
Greg
George Lewis:
    May 2013
Posted by Greg on Saturday, March 20, 2021 4:00 PM
gregbale
Now that's a doozie!
Toast
    July 2008
Posted by castelnuovo on Saturday, March 20, 2021 11:34 PM
Don Stauffer
Thanks all. Well, Censored happens, I guess. I did use super glue called Gorilla Glue (at least I diodn't put it in my hair Smile ).
Deconstructing this will be tough as the bombs are attached not just on the flat part but they have 2 little holes and the rack has 2 little sticks so it is apretty solid conection.
    July 2008
I needed a good laugh
    July 2008
Posted by castelnuovo on Saturday, March 20, 2021 11:36 PM
tankboy51
I did this with a British tank, too. Good thing with land vehicles is that there is a long fender plus one can add dirt, mud, equipment and startegicly placed cammo to hide the screwups. Smile
    July 2008
Posted by castelnuovo on Saturday, March 20, 2021 11:37 PM
Tanker-Builder
Yah Whoo!
I feel I am in a good company Smile
    September 2012
Posted by GMorrison on Saturday, March 20, 2021 11:52 PM
    October 2004
Posted by ikar01 on Sunday, March 21, 2021 4:55 PM
Don't be so hard on yourself.  During the war one of the 3 man S.A.T. patrols caught some ord. guys under the wing of a B-52D loading and arming 750 pounders while smoking some grass, so you may not be that far off.
Posted by keavdog on Sunday, March 21, 2021 5:22 PM
Don't sweat it brother.  I'd be more bothered that I would have to glue those finicky bastards on again - Hate attaching ordnance
And then there's this... so you really can't do anything wrong :)
Thanks,
John
    August 2020
Posted by Dodgy on Sunday, March 21, 2021 6:53 PM
No you're definately not alone. I glued the landing gear on a 48th Spitfire back the front, not so long ago. so I couldn't even claim it was a begginers mistake. Still don't know how I managed that......
I long to live in a world where chickens can cross the road without having their motives questioned
