Minimizing issues with those pesky super glue bottles!
    January 2012
Posted by DanR1967 on Thursday, September 9, 2021 10:22 PM
In regards to this type of super glue, which I get at Hobby Lobby:
I'm sure that others have had issues with the glue drying up long before the bottle is empty, or with glue amassing at the tip, causing the lid to not go back on properly, or with the tip itself getting clogged, etc. Well, I have been doing the following basic things to prevent this and they're working for me:
1) After every use (EVERY use, each time you squeeze a dollop out), wipe the tip with a paper towel and stick the cap back on.
If you go back later and the tip is clogged,
2) Use a pin vise to drill through the clog.
Repeat 1 and 2 over and over again. I have had zero issues with the bottle shown so far. The last one I used was a disaster.
Hope this helps!
Dan
https://danr67.imgur.com/
    April 2020
Posted by Eaglecash867 on Friday, September 10, 2021 6:04 AM
I have to use the pin vise to re-open the tip on my bottle of ultra-thin super glue, but not the medium-viscosity stuff that I have.  When you need another bottle of the medium, try the Gorilla super glue with the light blue cap.  It has a tip design that never clogs.  You just occasionally have to knock off the dried chunk of glue that collects around the rim of the tip, but the tip itself doesn't clog.  It also doesn't dry out in the bottle as quickly as others I have used.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
Posted by Tojo72 on Friday, September 10, 2021 7:19 AM
Eaglecash867
 Ditto and it lasts pretty long in the bottle too
Posted by midnightprowler on Friday, September 10, 2021 8:08 AM
A trick to keeping the cap from being permanently attached, put a little vaseline around the tip!
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
    February 2005
Posted by Glamdring on Friday, September 10, 2021 9:37 PM
I give the bottle a couple good taps on the table to knock any remnants from the nozzle back down after I drip some out.  This is probably an obvious one as well, but I make sure the CA bottle is stored upright at all times.
If a tip does clog on rare occasions, I have a few spare bottle tops for my Bob Smith Industries glue, I swap it for a clean one and soak the clogged one in acetone bath for a couple days.  It is good as new afterwards because the acetone dissolves the dried glue and has no affect on the plastic.
Robert
"I can't get ahead no matter how hard I try, I'm gettin' really good at barely gettin' by"
    April 2015
Posted by Mopar Madness on Friday, September 10, 2021 9:59 PM
I've read somewhere that storing CA in the fridge helps extend it's shelf life.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Saturday, September 11, 2021 1:34 AM
Mopar Madness
But not in the freezer.
 https://i.imgur.com/LjRRaV1.png
    August 2020
Posted by Dodgy on Saturday, September 11, 2021 7:25 PM
Mopar Madness
This is true MM. I have been doing this for some years and always clean the spout with paper.
I long to live in a world where chickens can cross the road without having their motives questioned
