I Wonder ????
    October 2019
I Wonder ????
Posted by Tanker-Builder on Wednesday, November 10, 2021 7:15 AM
Hi Ya'll:
      I have recently seen an ad for a Laser Cutter and it looks cool. Appears do do some fine work. What I am wondering is this. Can this tool be used on Sheet plastic?
    October 2004
Posted by ikar01 on Wednesday, November 10, 2021 8:02 AM
Not having any knowledge/experience with a laser cutter, I have to wonder, if it goes through wood by burning will it have enough power to go through plastic?  Also to be considered:
How smooth will the edges be?
Is the power variable?
Will some sanding be needed if something melts?
How much movability control will you have?
Will the trans-phase inducer hold up?
If cutting plastic, will it matter if you try cutting through the shinny side if you have one.  You don't want laser light bouncing off a shinny surface
And one of the most important questions....
What's the flight duration of a sparrow carrying a one pound coconut?
    March 2008
Posted by EasyMike on Wednesday, November 10, 2021 10:24 AM
Contact the manufactuer of the cutter and ask what types of materials it will cut.
2 cents
