Another dumb question
    January 2007
Posted by martin26e on Saturday, October 27, 2007 8:54 AM
wot is dry transfers and how to do apply them
im returing to modeling after sum time and never heard of them
any help would be great full
many thanks
Posted by Rob Gronovius on Saturday, October 27, 2007 9:29 AM
Dry transfers are rubbed onto the surface of the model. You use a stylus, like a dull pencil to rub the transfer into position. Another method is to rub the transfer onto a clear decal film sheet and apply like a normal waterslide decal.
    January 2007
Posted by martin26e on Sunday, October 28, 2007 12:12 PM
ok that clears thing's up
many thanks
    February 2007
Posted by DesertRat on Monday, October 29, 2007 10:58 PM
Actually, that's a new one to me too! Sounds kinda like that "Presto Magick" rubbing toys i had when i was a kid....
Warmest regards,
Roger
    March 2007
Posted by bondoman on Tuesday, October 30, 2007 1:53 AM
Dry transfers are a emulsion bonded "backwards" to a carrier film. They are a staple of the graphic design industry, and we call them rub downs.
The BIG problem is that they have a really short shelf life, like 6 months.
If you go into a art supply store and see transfers hanging on a rotary rack, don't buy them.
We order them to use within a week, and even then not often.
Dry transfer markings for hobbies are to be avoided, its bound to be old stock.
Look online for decal production techniques or services, even in these forums.
Bill
    May 2003
Posted by qmiester on Tuesday, October 30, 2007 6:16 AM
Back in the late 70s and early 80s, Letraset had a quite comprehensive line of aircraft dry transfers for 1/72 and 1/48 aircraft (and 1/72, 1/48 & 1/35 armor).  Initially, the biggest problem was getting them aligned/located exactly where you wanted them (once you started rubbing them, thats where they stayed - try to move them and they broke up).  Then it was discovered that if you opened the pack, used a few of them on a model and then stored the rest in the open pack, when you went to use them in a month or two, they wouldn't hold to anything.  Since you could buy a set of regular decals for the same price and they were still usuable after being stored for a couple of years, people stopped buying them and they were discontinued.  Letraset is still in business, producing letter sets of verious types for folks who need to make signs and placards (check in your local business supply shops).  And I believe they continue to make a product line for model railroaders.
Quincy
    August 2006
Posted by HawkeyeHobbies on Tuesday, October 30, 2007 8:49 AM
Old dry transfers can be resurected by holding them next to your body for about fifteen minutes. The warmth softens them and reactivates the stickiness. I set mine atop of my flourescent lamp above my bench which is slightly warmer than my body temp. Dry transfers should be kept in sealed ziploc bags with their wax paper protection sheet to keep them viable longer.
Gerald "Hawkeye" Voigt
