Aaronw wrote: |
Sorry no help, I use Bondo and Acrylics. I have one of those in the stash but haven't played with it yet. What do you think of the kit so far? |
The overall kit is good , little problems on the cockpits panels, maded with decals, but hard to see when the kit si done, i've added some piece for gunner visor and seat belts, rotors commands etc. on outside the main problems on the canopy , too little on width for the fuselage, and some minor problem on the engines section.
Basically italeri use two source for decals one bad and one great, i hope these is from great!!
Phil_H wrote: |
I am curious. Was there a particular reason for you to undercoat the entire model with Mr Surfacer? Generally I only use these primer products to fill small gaps. seams. scratches and pin marks, but not as an overall primer. Did you paint the OD straight from the bottle or did you thin it, and if you did thin it, what did you use as a thinner? PS: What did you use to clean your brush after applying Mr Surfacer, and did you use the same paintbrush to apply the OD? |
Generally i don't use primers, but i use a grey color chosen (model master or humbrol) between the bests that i have, time ago i've bought mr surfacer as general primer, and for instructions.. only in japanese. i've tested on various surface but the brush used was ruined; all the thinners i have at the time not working.
Recently found a commercial thinner at hardware shop (2€) so i tested it as thinner/washer and work good, so i decided to test on a kit.
Unfortunately with pure olive drab not worked as showed above. On the second attempt heavy thinned holive drab (MM) worked, now the kit is on the dry brush stage and look good. Soon i'll take some new pics to show the final result.
not able to talk about mr surfacer but i think that work better with acrylics paints.. then not for my kits..
I have a perverted idea to do with the mangusta...
