Hey all
Just a quick question -
Can anyone tell me how wide the AH-1 Cobra fuselage is, not the width from one stub wing end to the other, which is what is normally quoted, but the actual width of the fuselage.
I can't seem to find any decent pics with the dimensions on, hence why I'm asking this. Plenty for heli's like the UH-60 and UH-1's though.
Thanks.
I've misplaced my good Cobra book but seem to remember the width at the cockpit was 3 ft. This dimension was established by the width of the transmission support frame. I happended to have an old Revell UH-1D transmission well available to measure and it came out to 3 scale ft. Other than the nose and pilots door hinges this is the best detailed compared to the Panda/Dragon kits. If Academy would make an AH-1G comparable to the UH-1C we would have a great Cobra!
Clear Left!
Mel
Thanks Mel. That sounds about right as the cabin is only just wide enough to fit a guy in, probably no wider than my pine single bed. Lol.
Unfortunately for me no matter what scale I buy an AH-1 kit in it sounds like it won't be suitable for what I want to do, even a 1/24 scale AH-1 wouldn't be wide enough for what I need, and even if it is it'd likely be too long and heavy. I need about 1.5 inches width free inside to fit some extra parts and about 2 inches in height (or however high the cabin of a 1/48 UH-1 is, I really should measure mine) and I need to keep the weight down.
Having said that I will probably buy a 1/48 or 1/35 Cobra just to make up as a static model at some point in the future.
3 feet 2.62 inches. there was a mod near the end of its US Army life cycle that re-positioned the air intakes on the transmission cowling that only gave it a few more inches; but I can't find the exact number.
hope this helps
http://www.flickr.com/photos/34991991@N06/10415308414/
42 inches at the arc of the canopy, 36 inches at the sides
ISTR from the early '70s when I built the 1/32 Revell AH-1G in the info part of the instructions it claimed that its fuselage was "only" 3 feet wide.
hmills16 42 inches at the arc of the canopy, 36 inches at the sides
Never doubt a snake driver! Here's the pic from the AH-1G dash 10 showing all the main cobra dimensions.
Ray
Thanks Ray. I searched Google for hours over several nights looking for a diagram like that.
