How do I make decals look real?
    June 2005
Posted by SSgtD6152 on Monday, June 6, 2005 1:22 AM
How do I Make the decals on my models look real?
I'm building one of each A/C that we have in the Marine Corps.
So far I've made two CH-46's one for me and one for my GySgt that is getting out, one V-22 Deathsprey and a AV-8B lawndart. They look F-ing good but the decals just stand out and are all glossey.
How do I fix this?
I'm working on a F-18D now with alot of after market parts. Then I have one more Phrog to do with after market parts, and Im going to make my decals.
Thnks,
SSgt D
HMM-161
Phrogs Forever!!!
    May 2015
Posted by willuride on Monday, June 6, 2005 1:32 AM
Just spray your final flat coat after you apply the decals. That should make them flat and blend with your paint scheme.
On the bench Knoxville, TN:
1/48 Monogram F-4 Phantom "Black Bunny"  I wanted to relive the past....Never again
On the Bench Manchester, TN:
1/48 Revell F-18E
    June 2005
Posted by SSgtD6152 on Monday, June 6, 2005 1:36 AM
What do I use for flat coat ?
Posted by HeavyArty on Monday, June 6, 2005 1:38 AM
To get your decals to disappear into the model and look like paint, you first have to apply a glosscote to the area to be decaled. The smother the finish, the better the decal will adhere and the less chance of silvering. Silvering is when microscopic air bubbles are trapped behind the decal and light reflecting off them looks silvery-gray. Once you have glossed the decal area and let it dry, apply the decal, ensuring that all air is pressed from behind it gently with a soft cloth. Let the decal dry and set up for a short time. Once the decal is dry, seal it with a flatcote to blend it into the surrounding area and remove the gloss finish you applied to the decal area. It may take a couple dullcotes to blend it fully. Using this method will prevent silvering and your decals will be permanantly affixed to your model.
    June 2005
Posted by SSgtD6152 on Monday, June 6, 2005 1:44 AM
So I need to go to a model shop, and ask for flat coat and gloss coat.
    June 2003
Posted by Avus on Monday, June 6, 2005 2:22 AM
In addition to HeavyArty's method you cuold add:
- a gloss coat over the decal before applying the matt coat
- use a solution like Micro Sol. This solution makes decals softer and so they adapt better to irregular surfaces.
Klaus
Thanks to ImageShack for Free Image Hosting
    May 2015
Posted by willuride on Monday, June 6, 2005 4:54 AM
Yes that will be your best bet. clear dull coat or Flat coat.
1/48 Revell F-18E
    June 2005
Posted by SSgtD6152 on Monday, June 6, 2005 8:53 AM
Thanks,
    February 2005
Posted by TommyHawk on Monday, June 6, 2005 9:36 AM
You can also (carefully) apply any weathering/chips/scratches you're doing to the model itself, to the decals...
    January 2005
Posted by jinithith2 on Monday, June 6, 2005 4:19 PM
first, lay down a coat of future, put the decals on, lay on another coat of Future, and then your choice of clear coat
