Repeatable rivet creation on 1:24 scale Huey - How??
Posted by Anonymous on Monday, October 24, 2005 2:50 PM
To all,
I am building a large scale (1:24) Huey uh-1B helicopter and require advise about how to create rivet heads. I am keen to open this up to the whole of the forum.
There are missing lines of rivets on my model that are both missing and will need replacing after sanding and scrapping.
As you can appreciate they are of a reasonable size and at a guess are 0.3mm (0.012") in diameter and proud of the surface.
Its a tough feature to recreate, but has anyone any ideas?
Tomcraft66
Posted by grandadjohn on Monday, October 24, 2005 5:29 PM
There is no easy method, but expect to spend a lot of time making the rivets, may want to check out railroad detail parts
    November 2013
Posted by intruder_bass on Monday, October 24, 2005 5:47 PM
Since the Huey has raised rivets on the hull, You have 2 choices. Both of them are pain in the a...Wink [;)]
#1 If you have enough pations take a 0.3 mm sterene rod from Evergreen and cut as many pieces (1mm) as you need and then glew them on the hullWink [;)] If there are not too many of them to be recreated - it won't be so annoing.
#2 Use alluminium foil. Cut out exact shape and size of the panel where rivets are missing. Then turn it upside down, put it on pack of news papers and make resessed rivets with the needle. Dont press to hard not to penetrate the foil. Turn it back and glew the foil on hull. This method is really hard - I myself tryed it only on small panels - but it works awesome! Just need some practice.
Check this out
Here is Dacota in 1/72!!!!
All panels and rivets on them made with foil method
http://www.sukhoi.ru/forum/attachment.php?attachmentid=45993
http://www.sukhoi.ru/forum/attachment.php?attachmentid=46843
http://www.sukhoi.ru/forum/attachment.php?attachmentid=46844
http://www.sukhoi.ru/forum/attachment.php?attachmentid=45994
http://www.sukhoi.ru/forum/attachment.php?attachmentid=45995
Good luck
Posted by Anonymous on Monday, October 24, 2005 7:42 PM
Here is one more method , using Elmer’s white glue. Once you have your model finished and ready for paint, pour some glue down on a piece of cardboard and using a tooth pick up some glue and place it where the rivet should be. Once dry you’ll have a hard raised rivet. Work great, did this way many times myself and it’s faster. Best part is, if you mess up it takes no time in fixing it right. I suggest that you try it on a scrap piece of plastic first so you get the feel, understanding and how much is needed.
Posted by Anonymous on Tuesday, October 25, 2005 11:39 AM
1mother,
I like that glue idea. the thought of being able to erase any accidental rivets immediately seems like a good idea!
Really helpful generally though all who contributed. I will check this post on and off for a while so if anyone has anymore bright ideas please don't hesitate to add something.
Thanks
Doug
Posted by HeavyArty on Tuesday, October 25, 2005 1:58 PM
Don't know if it will work for 1/24 scale, but I have heard about getting the Britta water filters and opening them up. They contain a bunch of conical, half spherical beads that are perfect for rivets. All you do is glue them on. One filter yields hundreds of rivets.
