Question to Mel and other Uh-1C specialists :)
    November 2013
Posted by intruder_bass on Thursday, June 29, 2006 10:55 PM
Returned back yesterday to my Huey C transmission compartment detailing.....and faced a little delema. According to Manual there is a "thing" (I marked it with red) on the front of the transmission module... but on photos of real helo I couldn't  find anything that looks like it.
Question is - what is it? Should it be there on "C"?
Thanks a lot!
Andy
    August 2004
Posted by Chief Snake on Friday, June 30, 2006 8:16 AM
That is the accessory drive for the standby generator. Not there on B/C models. The illustration you have is for D/H models.
Chief Snake
    November 2013
Posted by intruder_bass on Friday, June 30, 2006 5:56 PM
Thanks Chief!
Now I have to ripp it off my module :-)) but thats OK cuz I'll save it for future projects...
Andy
Posted by Melgyver on Saturday, July 1, 2006 9:49 AM
Chief Snake is "right on the money"!   Do you have my pictures that were posted some months ago?  I have a new scanner and can E-mail some I took of an old "Mike" model which would be the same for the "Charlie".  This one as well as a lot of "Charlie" models have an "extended" collective lever which had the pivot point attached to a bracket and "link" on the fwd right edge of the transmission about 1:30 clock position.
Clear Left!
Mel
    November 2013
Posted by intruder_bass on Saturday, July 1, 2006 10:42 AM
PLEASE!!!! Mel it would be very helpfull - your pics are the main reference sourse for me...
my e-mail is the same
intruder_bass@hotmail.com
Andy
Posted by Melgyver on Monday, July 3, 2006 12:49 AM
Andy sent me a few pictures of his progress so far.  He is doing a good job.  I'm afraid my pictures will just "complicate" his project!  Heh, heh!  One reason I've never finished mine!  I'm way too "close" to the subject!  Maybe Andy's build will get me off my "duff" and finish one of the two Sharks I've started.  A couple shots of one of the cockpits, stock except for the map case, and the transmission and rotor assy.
Clear Left!
Mel
    November 2013
Posted by intruder_bass on Tuesday, August 8, 2006 8:45 PM
Got another rookie question))))))
Here are couple of pics for easier understanding of what I am talking about.
There is a big pipe (I called it PIPE 1) coming out from top of rear half of engine and goes ether into "HOLE 1" from the second pic, or into deck or somewhere else...
Can somebody give aproximate directions on where this thing goes? BTW is it a fuel pipe?
Second question is about "PIPE 2"
I can see where it begins but have no idea where it goes... Any hints? Looks like on the pic it is disconnected.... or it goes into the deck
the last question  -  marked with "?"   It is obvious that there soppose to be another pipe there.... Where this one goes?
Oh......those pipes drive me crazy....Angry [:(!]
Thanks for help!
Andy
Posted by Melgyver on Wednesday, August 9, 2006 10:15 AM
Andy,
Pipe #1 is the main engine "bleed" air supply to power the oil cooler fan.  It is mounted below the engine deck where Hole #1 fitting is located.  I don't remember if the UH-1C's had a bleed air powered fuel pump or not.  Pipe #2 is the main incoming fuel supply hose to the fuel filter housing and it is attached to a fitting in the floor behind the fuel filter.  The red "nob" is the break away crash worthy 90 degree fitting for the fuel supply hose that goes to the fuel control on the side of the engine which is not there.  I have a few more pictures I can scan later and send to you that will position Hole #1 fitting at the engine deck better.  A couple are of a UH-1H fuel fiter housing and where the hose attaches to the engine to give you a better idea.
Clear Left!
Mel
    November 2013
Posted by intruder_bass on Wednesday, August 9, 2006 8:26 PM
Mel,
thanks for info! And I would really appriciate any other photo you send me! as I said before - your pics and explanations are the primary reference source for me.
PS
so PIPE 1 goes into Hole 1 or right beside it?
Andy
Posted by Melgyver on Wednesday, August 9, 2006 10:47 PM
Andy,
Roger, Pipe #1 (actually a braided stainless steel line) would plug into "hole" # 1.  I've gone through all my Huey references and no luck on a good shot of a UH-1B or C left side of the engine other than what you posted.  I could really kick my "butt" for not taking some shots of the B's we had in the late 70's for a short while when I was in the Army Reserves.  I had saved all the manuals on B/C/M's in a locker and my coworkers went on a cleaning spree when I was on vaction one time and threw them away.  I still get pissed thinking about it.
Clear Left!
Mel
