razorboy wrote: |
razorbot, that is a brilliant method! The only thing I would say to improve it maybe a little but would be to use thicker craft glue--white glue--to help fill in some of the larger spaces between the rocks. If you look at some rock walls, they have earth and dirt between them, especially at the lower levels, where they catch leaves, litter, and whatnot that the wind blows up against it. You can even push little balls of tinted Cellucaly into the bottom peices and give it a somewhat more robust character.
Having traveled Europe extensively, I'll see if I can get some photos of fields and walls up here in a little bit...I've got some photos, I believe?
