Laser cut windows/glass.
    August 2005
Posted by downtowndeco on Saturday, October 25, 2008 5:56 PM
I received some samples of the wood laser cut parts I needed to complete my kits. I gave them a few light coats of dark green spray paint, added the glass (also laser cut), misted them a bit with flat black to "dirty them up" a bit & glued them in place.  Comments?
Randy Pepprock
    April 2008
Posted by smeagol the vile on Saturday, October 25, 2008 7:19 PM
The second floor doesnt look right...
When I did when I made broken glass for my last project.  I figured where I wanted the glass to have been hit (by bullets.  From there I put a bullet hole with a pin vice, then cut out crack lines from there, if more then one crack line hit, I would cut out that section.
When you just cut jagged edges like you did it looks less then realistic.
    August 2005
Posted by downtowndeco on Saturday, October 25, 2008 7:27 PM
"Bullet holes"? I was thinking more concussive damage from a B52... :  )
Randy
    June 2008
Posted by Hans von Hammer on Saturday, October 25, 2008 7:50 PM
I think it's been pulled off rather well... I'm no fan of buying stuff I can make, but those look quite realistic... There's a couple that have a bit too much glass left, IMHO,  but windows kinda do their own thing...
    April 2008
Posted by smeagol the vile on Saturday, October 25, 2008 8:00 PM
Well, if it were hit by a a B52 the building would not look in so good condition, I wouldn't think
    August 2005
Posted by downtowndeco on Saturday, October 25, 2008 8:19 PM
The back collapsed, a part of the front survived. Sheesh! :  ).
Randy
    June 2008
Posted by Hans von Hammer on Sunday, October 26, 2008 5:07 AM
Don't know much about concussion and blast-damage, do ya...Wink [;)] That or yer just bein' silly, ya 8-ball...Eight Ball [8]   Aside from the obvious damage to the back of this building, even if they miss, bombs and shells dropping close enough to shatter windows but far enough away to otherwise leave a building unscathed is pretty common, Smeagol... I'm pretty sure you've been in a thunderstorm that had a few window-rattlers... Principle's the same... The shockwave of compressed air caused the windows to shatter, not fragments or flying debris.  Or bullets...Big Smile [:D]
    February 2007
Posted by Geomodeller on Thursday, October 30, 2008 4:33 AM
Depends what type of glass you are trying to replicate. Modern safety glass can absorb the impact and shockwave of a bullet. Plexiglass (perspex) sometimes cracks or shatters and sometimes just takes a hole.
But window glass is pretty darn fragile stuff and generally shatters into small fragments or larger jagged sheets, depending on its thickness & chemistry.
I agree however, that a building with that much damage probably wouldn't have much glass left at all.
    August 2005
Posted by downtowndeco on Thursday, October 30, 2008 9:42 AM
Thanks to all that replied. I got really positive feedback on this (on other forums as well) in general. To those that don't think that this much glass should be showing after a bombing raid I suggest simply leaving it out (it is optional) or snipping some of it so there is not so much. Clip up the scraps w/a pair of sissors & leave the shards laying in the rubble. They pick up light nicely & look pretty good.!
 IMO this glass looks even better in person. It is a delicate little detail that really adds a lot to the scene.
 Cheers
Randy Pepprock
Dioramas Plus
    March 2008
Posted by EasyMike on Thursday, October 30, 2008 10:34 AM
 downtowndeco wrote:
...It is a delicate little detail that really adds a lot to the scene....
I disagree, but then I didn't buy the stuff.
Smile [:)]
    August 2005
Posted by downtowndeco on Friday, October 31, 2008 8:14 AM
Thanks for the support Mike! :  )
Randy
Smile [:)]
    April 2008
Posted by smeagol the vile on Friday, October 31, 2008 8:53 AM
I think it coudl have ALOT of uses.  I made my own, for my suburbs of leningrad build I did, it was a pain cutting all taht clear plastic.
