Another first attempt from a newbie....
    November 2008
Posted by Gnet on Saturday, November 22, 2008 3:13 PM
Greetings!
I would greatly appreciate opinions and insights from y'all on my first attempt at diorama building. I picked up a copy of Shep Paine's book and followed his instructions as best I could for most everything here. Things have changed since the last time I built a model about 20 years ago.
I thought I would start small, focus on some details, see if it was fun or tedious, and then maybe move to bigger things with better materials. The figure is a conversion from the 1/35 mg42 carrier in the Tamiya BMW R75 kit. (I like this guy because he has a war weary face.) I had in mind a scene from one of my favorite books "Archangel", in which the protagonist digs up a mysterious metal box and has to find some place secret to look at the contents.
The right hand is the biggest weakness, I think, and I obviously have A LOT to learn about figure painting.... I rather like the table cloth, though I couldn't continue the checker pattern in the folds along the sides. Any ideas?
The hay is also much too coarse. I used some rope fibers, the upside is the variation in fiber thickness. Any ideas on how to model hay?
I really enjoyed making this. Modeling the details are really a lot of fun to think about, and I found many great ideas on this forum.
Thanks!
gnet
    January 2007
Posted by the doog on Saturday, November 22, 2008 4:53 PM
Gnet, it ooks fine, for a first attempt; my biggest problem with it would be that, if you hadn't explained it, I never would have known what you were really trying to portray?
Technically, diorama's should tell a story to the viewer. While yours is certainly enigmatic, you should try to clarify your composition to the viewer in a better way.
Perhaps the soldier could have been a llittle more "cautious" or "paranoid" looking? Like, maybe looking behind him more, while holding an appropriately-strange-looking box? What you have there looks like a guy sitting down to eat solo with his ammo can. The setting looks like its out in a field somewhere--not exactly "private" wouldn't you say?
Figure painting is one tough discipline! Just keep practicing, and researching and reading up on it. You'll improve slowly, but don't get discouraged! Big Smile [:D]
    October 2007
Posted by razorboy on Saturday, November 22, 2008 5:38 PM
I think aside from the non-self-explainatory story line (doog pointed this out) , you did a great job.  Nice work with the "accessories" - a good first effort.
razorboy
    June 2008
Posted by Hans von Hammer on Saturday, November 22, 2008 6:23 PM
Myself, I raid dollhouse websites and print out wallpaper and such... Could easily be use for tablecloths..
Several, but I think yours is just as good as any I'd suggest.  I knew it was hay (or straw) immediately, and that's what you want to have happen.
For just gettin' back in and tackling a figure conversion right outta the chute, I think you've done extremely well technically... Other than the story-line, I'd call it a first-time GO...
(I thought it was a work-in-progress and he was perhaps meeting up with a French farmgirl for a little black-market dining in a barn...)
    November 2008
Posted by Gnet on Saturday, November 22, 2008 6:58 PM
Doog, Razor, & Hans:
 Thanks so very much for looking at this effort. I really appreciate you steering me in a direction that, as a novice, I can control i.e. the storyline and composition, and not the technical details (like the paint job) that I don't feel experienced enough to do anything about (yet!).
I think that I could do better to suggest a barn interior, for example, by adding implements or even a wall.
I really like Hans' idea of showing a tryst, say, with a girl hiding behind a barrel. That would be pretty evocative. Exchange the ammo box for a sidearm, and add a food basket on the table. Very, very cool idea.
The figure conversion involved bending the arm joints and tipping the head slightly to the side. I cut a notch in his neck, then heated the neck over a candle and bent to shape. Unfortunately, I melted the poor sucker's ear off.... That needs work.
    June 2008
Posted by Hans von Hammer on Saturday, November 22, 2008 9:50 PM
Feel free to run with the idea if ya want, Pard..
Suffered from that m'self, once upon a time.  Nowadays, I saw the heads off, carefully going around the collars until I can snap it off... Then I clean it up a bit, drill a hole in the bottom of the head and one in the torso, then insert a length of straight-pin "spine" into the holes.  Get the head positioned where I want it, glue it down, then fill in the gaps with Testor's putty through a precision gluing tip, then sand and paint...  I pretty much do all the joints that way now... Straight pins are cheap, but any small diameter wire would work... Even stretched sprue works...
