Gun for Hire: finished!!! 8-29
    January 2009
Posted by camo junkie on Tuesday, August 25, 2009 3:16 PM
hey guys, just showing off my latest mini dio. this is still a w.i.p. but its only like a 2 to 3 day thing b4 its completed. i wanted to take a temp. break from my mayhem dio and do something different. this is only going to have one figure in it and it is my new world miniatures private contractor. the figure is still in the painting stages and i have to do the ground work but like i said, in a couple of days it'll be finished!!! that i promise!!
thankfully the talented chris (po995) sketched me (well, in this case sketched it for modelcasm but i ran with the building/wall) a drawing of what i had in mind for an idea for scott. right now the building/wall is all i have completed but again, it wont be long!!! hope you like your "vision" coming to life chris!!! thanks again buddy!! and thank u scott for letting me run with this!!
i made two of them just because, plus i will use them both, one at a time though. one was made using styrene for the walls, styrene bricks then spackling compound over the bricks, sanded smooth then scribed with my exacto the cracks, bullet holes. alot of the cracks and stuff i would've put in my mayhem dio but that was of course one of the things i thought about after the fact.
the second one i made from styrene walls, covered in spackling compound, when dry scribed the brick pattern with a pointed file, then applied more spackling compound on top of that, sanded smooth then scribed cracks and bullet holes like the first one.
first is chris' picture for scott
this is the all spackling/scribed bricks one
hope you guys like it or at least will when its completed!!! Big Smile [:D]
"An idea is only as good as the person who thought of it...and only as brilliant as the person who makes it!!"
    December 2003
Posted by psstoff995 on Tuesday, August 25, 2009 3:23 PM
Woah!! I really like how this is turning out, great rendition- even the red graffiti (which I'll admit, I took the idea from your Mayhem dio Whistling [:-^]) Nice weathering job, great detail Thumbs Up [tup]
Edit- I like the character of the scribed one, while the styrene bricks have more uniformity, they have less character, tough call, guess it depends on what one’s going for.
-Chris
US Army Infantryman
    January 2009
Posted by camo junkie on Tuesday, August 25, 2009 3:31 PM
ya know chris, its funny you say that but i thought the exact same thing with the two of them!! i like the scribed brick one myself! and...lol, i used the same graffitti i used on the other one only "part" of it. glad you like it...it's your "picture"!! Big Smile [:D]
    August 2006
Posted by arkhunter2002 on Tuesday, August 25, 2009 3:53 PM
Lookin really good!
What colors/technique (spray it black then dry brush?) did you use for the final coat?  I may use it as I kind of want the house in my fast roping dio to have a similar color/finish...
    December 2003
Posted by psstoff995 on Tuesday, August 25, 2009 3:59 PM
yeah but you definitely gave it your own flair, it looks really good- the picture was 2D and I'm glad it inspired you, because I don't think I would have been able to do the 3D version this well, or put it together in a few days like you have. Hey- maybe I'll be able to pick up some tips and better prepare myself for little vignette projects...
Maybe I'll throw a blue door on mine haha
-Chris
US Army Infantryman
    January 2009
Posted by camo junkie on Tuesday, August 25, 2009 5:56 PM
there ya go, use it on yours although...i asure you i will build that one as well soon enough!!
ark lets see, it's the same technique i used on my mayhem dio in that i primed the spackling with flat black paint, then a.b. painted the spackling (non brick areas) a medium grey. a.b. painted the spackling areas after that with humbrol #187 sand. i made sure i left the grey around the cracks and spackling not covered (you'll see in the picture). very similiar to painting armor/panel lines with an a.b.!! then a.b. painted the (btw a.b.=airbrushed) bricks humbrol #84 mid stone. after that took my same med. grey and a.b.'d the lines in the bricks. (you could probably save this step by simply painting everything med. grey then adding the sand and mid stone colors while leaving the edges of the grey showing).
anyway, after all that, i applied a raw umber wash to all the lines and details. once done i took a wide brush and using just mineral spirits, lightly (very lightly, the trick is to not lift the paint you laid down as it isnt "dry" yet) whisked my brush of just mineral spirits across the entire thing, bricks and all. what this does is "cleans up" the wash residue and also blends & bleaches the paints. let that dry then dry brush lighter shades while progressively adding white. make since?? let me know if ya need any more info or whatever ok ark. i'll help ya any way i can. Big Smile [:D]
btw, i was thinking of calling this "blackwater...red river" but wasnt too sure on that!
    December 2003
Posted by psstoff995 on Tuesday, August 25, 2009 6:38 PM
Interesting title- sounds like a good book Thumbs Up [tup]
-Chris
US Army Infantryman
    January 2009
Posted by camo junkie on Tuesday, August 25, 2009 6:41 PM
thanks, i guess i can get to writing that too! Laugh [(-D] yeah, as if!! sounded good, kind of a play on words and considering what they did over there makes perfect sense!! however, ya seen the title here FIRST folks, so in theory it is copywrite protected!!! Mischief [:-,]
    March 2008
Posted by modelchasm on Wednesday, August 26, 2009 7:31 AM
HOLY CRAP, TOM!!!! Those buildings/ wall look OUTSTANDING!!!! Seriously! Nice job.
I personally, like the first one. I guess it's the one w/ styrene bricks .... I just like how the brick/ mortar lines are a little more defined. They're probably not to scale, but I think whn things are a little more defined in smaller scale, they just look more real. But that might just be me.
Again, nice job on this one. Will be watching .... Thumbs Up [tup]
"If you're not scratching, you're not trying!"  -Scott
    January 2009
Posted by camo junkie on Wednesday, August 26, 2009 7:36 AM
yeah, i hear ya and everyone has their preferences. thanks though for the comps. as i said, the level of detail is what i wanted to put in my mayhem dio...but again, thought of it after the fact. not sure also if i would've been able to do it as i put such a thin layer of spackling compound on it...but whatever...will do for the next one (much smaller btw)!!!! Laugh [(-D]
    March 2008
Posted by modelchasm on Wednesday, August 26, 2009 7:51 AM
I hear ya. Besides, I think that you "made up for" the detail in your figs etc. I think that you're building in mayhem is perfect. Don't have 2nd thoughts about it ....
I went back and re-read this thread again, and chris brings up some good points. While I think that the styrene brick wall looks good, it's not all that accurate when talking about Iraq/ Afghan. The bricks are more manufactured than they are hand-made. I think he called it .... character.
Just curious, just how did you paint on the lettering again? And how did you come up w/ the phrase?
    January 2009
Posted by camo junkie on Wednesday, August 26, 2009 8:05 AM
well, the phrase is probably just jibberish in that i made a stencil (cut out of 3 x 5 card) for my mayhem dio and only used a part of it for this then air brushed it on...figured it looked good and that was good enough in this case. i also like the scribed brick one. i'm sure if i was really careful i could've scribed them straight and made them uniform, but i didnt think it mattered and in the end like ya said, they're hand made anyway and probably not all that straight!! Big Smile [:D]
    January 2009
Posted by camo junkie on Wednesday, August 26, 2009 9:38 AM
btw scott, rereading your last post i think you were asking me how did i come up with the phrase, like i said while probably jibberish because its only "part" of the whole phrase, i actually took the "arabic wording" from a computer video game (battlefield 2) i have!! alot of my mayhem dio was actually forged from that game...LOL. anyway, i would do a print screen on areas i "wanted" then would paste them into word, scale to the size i wanted then print them out. for my "stenciling, i would put the picture i printed on a window so the outside light would show through, then place and draw/trace over it on my 3 x 5 card then used my exacto to cut it out and airbrushed away...! make sense? Cool [8D]
    March 2008
Posted by modelchasm on Wednesday, August 26, 2009 9:44 AM
Thanks Camo!! That's exactly what I was looking for. Such a simple technique too. I'll have to store that one away in my "how-to" book!
BTW ... my neighbor just drove by a gave me a funny look as I was holding the printout to the window ... gee, thanks! HAHA!!!
    January 2009
Posted by camo junkie on Wednesday, August 26, 2009 9:48 AM
that's why i used the door out onto my deck (the back one) buddy!!! no witnesses!! Wink [;)]
    August 2006
Posted by arkhunter2002 on Wednesday, August 26, 2009 10:34 AM
lol camo, I took a lot of ideas for buildings from BF 2 also.  I'm basing my fastroping house from one of them in karkand...
Thanks for the how-to on the wall.  I don't use enamels but I'll find a way to do this with acrylics when I get home...
    January 2009
Posted by camo junkie on Wednesday, August 26, 2009 10:58 AM
hey a fellow bf2 guy!!! that karkand is actually where almost every inch of that dio came from...Laugh [(-D]...if ya look real close you might even recognize some things from it...Whistling [:-^]. as far as the paints, well, ya got the idea and im sure you can throw something together that will work for ya!!! good luck!!
    March 2008
Posted by modelchasm on Wednesday, August 26, 2009 10:58 AM
Good luck w/ acrylics, ark .... see here's where I'll fight for enamels and oils ... I know, GASP!!! ... Whatever.
Acrylics are great for painting flesh, airbrushing, etc, etc, etc ... but they dry WAY too fast to really get a good weathering layer down. Especially, when dry brushing. Too, you can't really "water" it down too much either as it will just start to pool the paint in one spot. I don't use much oil (as honestly, I don't feel like I know HOW to use them), but enamels are perfect IMO for weathering. They take a little time to dry when dry brushing, and thinning them isn't an issue either.
Anyway ... just IMO ...
    January 2009
Posted by camo junkie on Wednesday, August 26, 2009 11:02 AM
didnt want to say anything...just highlight the quote only!! Laugh [(-D]
    March 2008
Posted by modelchasm on Wednesday, August 26, 2009 11:12 AM
It took you four minutes to reply to that .... you disappoint me. Laugh [(-D]
    December 2003
Posted by psstoff995 on Wednesday, August 26, 2009 11:12 AM
Just wondering- how hard was it to cut in bullet holes in the styrene bricks? I notice you only had one in the styrene, but the spackling is all lit up.
Also I think that’s pretty interesting that the graffiti came from a video game- especially since jthurston translated it into munfajarat or some kind of bomber warning/calling card. I guess Battlefield 2 put some research into it.
-Chris
US Army Infantryman
    January 2009
Posted by camo junkie on Wednesday, August 26, 2009 11:21 AM
yes, scott, it took me 4 minutes because i couldnt stop laughing for 3!!! Laugh [(-D]
chris, im glad u noticed that. i only made one in the styrene as it just didnt give me the same results i got in the other one so rather than risk ruining it, i stopped after just the one! and yes, bf2 people did their research and got it damn close!!!
    December 2003
Posted by psstoff995 on Wednesday, August 26, 2009 11:27 AM
Yeah, I can understand that. Maybe you could have tried drilling it? It looks like you used an xacto blade. Don’t get me wrong- I think it looks great as is (both of them!), was just thinking about future projects. I like the texture of the spackle- but as Scott was saying, the styrene gives better mortar depth and manufactured uniformity, it's too bad you couldn't somehow combine the two...
-Chris
US Army Infantryman
    January 2009
Posted by camo junkie on Wednesday, August 26, 2009 2:21 PM
well, doesnt matter anyway. its done. scott kinda recanted his thoughts about that one anyway. i like the all spackle one more than the styrene just because like you said, it has character.
    December 2003
Posted by psstoff995 on Wednesday, August 26, 2009 2:40 PM
Thumbs Up [tup]
-Chris
US Army Infantryman
    August 2006
Posted by arkhunter2002 on Wednesday, August 26, 2009 4:17 PM
MC, I guess I was referring to airbrushing the acrylics for the main building colors, and then weathering in oils.  I have some decent oils at home, just no enamels (well, I have like spray cans of quick dry enamel black and white)...
But yeah, I think that cod4 also has some pretty good graffiti stuff.  I'd have to re look through it, but I like the way the bf2 buildings were better...
    January 2009
Posted by camo junkie on Wednesday, August 26, 2009 4:31 PM
cool ark. yeah, that should work for you with the airbrushing, etc. never played cod4. can always use more graffitti so if ya can and want to email me it...but up to u. mustangtom70@yahoo.com thanks.
    December 2003
Posted by psstoff995 on Wednesday, August 26, 2009 4:48 PM
I'm looking forward to COD:MWF2 -but is that COD 6? Or COD4 2?
lol I think the graphics in COD were much nicer, probably the only thing that kept me away from the Battlefield series. Blush [:I]
-Chris
US Army Infantryman
    January 2009
Posted by camo junkie on Wednesday, August 26, 2009 9:10 PM
too bad chris, ya missed out. cant say anything about cod but b.f. series was good!
as far as my dio, the ground work is drying right now. have some odds and ends to do with that then its finishing painting the figure. could've at least did the flesh on my figure today but was being lazy, just did the ground work. did paint the flesh base coat though today!! Big Smile [:D]
    March 2008
Posted by modelchasm on Wednesday, August 26, 2009 10:09 PM
HOOO-RAY for lazy days!!!Propeller [8-]
