How do I stick 1/48 Tamiya tanks on bases.
    January 2008
Posted by somenewguy on Monday, September 21, 2009 7:41 PM
G'day all.
I have a problem. I have begun my first diorama base. Just a small one. I will use either my Tamiya 1/48 Panther G or Sturmgeschutz III Ausf. G. But I recently got struck with the question "how am I going to bond it to the base" after I remembered that the hull/s are metal so I can't drill it to put a screw in it.
Any suggestions?
Cheers!
At the end of the day one's work may be completed but one's education never!
    November 2004
Posted by Bronto on Monday, September 21, 2009 7:54 PM
You can drill through the metal hull just like a plastic one to put a screw to hold it to the base, just drill the hole before you start adding the plastic parts so they wont break off while you are holding it.
Posted by airtrans Crash on Thursday, September 24, 2009 6:59 AM
a coabalt bit will rip through metal like you wouldn't believe. just be delicate
 A man's country is not a certain area of land, of mountains, rivers, and woods, but it is a principle; and patriotism is loyalty to that principle. ~George William Curtis
    January 2009
Posted by eptingmike on Thursday, September 24, 2009 8:43 AM
Well if you think it isn't going to be shaken around or shipped across the country you could just try gluing it to the base.  You could use hot glue or wood glue...maybe?  Otherwise I would have to agree with the other posts.
Horten_IX_Go-229
