Junkers Ju-87 and Me-262 - Little Diorama on 1/144
    October 2003
Posted by lucke.stz on Tuesday, January 5, 2010 3:29 PM
Hello guys,
I have working on i since july 2008...
The project is inspired by some pics that I found on Internet:
Take a look at the Stuka on background...
"To fly it is the magic that happens between the physics and the dream"
    October 2003
Posted by lucke.stz on Tuesday, January 5, 2010 3:31 PM
I starded by buildin the old barn, I draw a little plans on Corel Draw and starts to build.
I make some strips from 1/32 scrap balsa, and with ciano, started the construction.
By de pics I dd some scale down to size, it is not exactly, but is but closer to  the real
Some pics:
Some dry fit to show the size and scale:
    October 2003
Posted by lucke.stz on Tuesday, January 5, 2010 3:32 PM
The, I make some strips from 1/64 Liteply, so glue with CA on the structure, looks good :D :D
    October 2003
Posted by lucke.stz on Tuesday, January 5, 2010 3:35 PM
I have worked on the roof structure:
    October 2003
Posted by lucke.stz on Tuesday, January 5, 2010 3:36 PM
Now the best part :D I like a lot the weathering result :D :D I´, really surpassing me on the diorama :D :D
The pics say by itself:
The tiles I made with a a help of my friend Reducino, with aluminum foil for cooking and some needles.
I just glued the needles side by side and then press the foil to ge the "corrugated" format.
The result looks good. On the outside I paint on rust, and Inside with withe aluminum.
And a pic b&w looks good :D :D
    October 2003
Posted by lucke.stz on Tuesday, January 5, 2010 3:38 PM
Tha fase 1 is now finished, let´s start the plane :D
The old barn finished:
    October 2003
Posted by lucke.stz on Tuesday, January 5, 2010 3:39 PM
I started the build, not too much work, I´m without inspiration today :)
The kit is an Eduard J-87D - #4416
The kit tree:
And here the fuselage, the canopy is closed, so any interior details are on the kit.
So I open it with an Dremel and some sandpaper:
With a plasticard (0.5mm) I did the cockpit floor and add the panel, the seat are from dentist resin, and the rear seat are from plasticard too.
    October 2003
Posted by lucke.stz on Tuesday, January 5, 2010 3:40 PM
finished the interior, not too much details, cos the canopy will be closed, I promisse details on the Me-262 ok ;)
Let´s to the pics:
With a PE saw I remove the elevator to make it downed...
Wings glued and eelevators too, add the PE airbrakes and elevator struts...
Undersides painted...
Camo masking, with tamiya tape,
Painting, Gunze paints, and Testors AZTEC airbrush..
The result was this:
    October 2003
Posted by lucke.stz on Tuesday, January 5, 2010 3:42 PM
Masking to paint.. this mask gives me a lot of work to do...
Painting:
I like a lot the Gunze paint finish:
Now the model almost done:
I finish the landing gear.
On the rear wheel I did a hand work, it ´s to little to mask and paint with airbrush:
On the other gears I mask na paint with airbrush
The model almost done:
Here a fit to inspire the work :D
I paint a little strip of a decal sheet to make some strips to canopy...
    October 2003
Posted by lucke.stz on Tuesday, January 5, 2010 3:43 PM
Aplyied some decals, this is the little one:
After decalling the models looks this:
So, the hardest thing to do, the patterns on fuselage, I tryied to use a Nankim Pen, but does not work, the paint is not enough, I made an adaptation with a draw compass, I don´t know the name of this in English..
After aply, the model looks this:
    October 2003
finish the part 2 - The Stuka...
I use some heat shrinking tubing to do a exaust covers:
Add some extra PE parts and make some weathering and the model is finished :D:D
Now lets the part 3 - The Me-262....
    October 2003
Posted by lucke.stz on Tuesday, January 5, 2010 3:44 PM
So lets see with are to comming..
The kit:
The PE and Resin Set
    October 2003
Posted by lucke.stz on Tuesday, January 5, 2010 3:45 PM
a little work on the model, today I´m do not too much inspired, so I don´t finish the cockpit, need to go on the seat belts..
Let´s to the pics:
    October 2003
Posted by lucke.stz on Tuesday, January 5, 2010 3:46 PM
according to the pics, the 262 on front the Ju-87/barn, have some panel opened of the leff engine, so I cut the panels with a PE saw and add the details using some sprue and a soda straw, now is just paint to see it finished.
    October 2003
Posted by lucke.stz on Tuesday, January 5, 2010 3:47 PM
finish the engines, paint with alumminum Vallejo paint before the paints, and detail/wheatering the engine details, let´s to pics:
Here with the figure (from Preiser)  the I´ll use:
    October 2003
Posted by lucke.stz on Tuesday, January 5, 2010 3:48 PM
I´m working a lot on the last days, so don´t having too much time to modelling :( :(
Ready to paint:
Painting aplied, I use here the salt technique to make the wheatering
Finished, I did a little washing on it
Start to work on the landing gear:
Add too this piece on PE in canopi
    January 2012
Posted by I make stuff on Tuesday, January 5, 2010 6:44 PM
The tininess is only surpassed by your dexterity and patience.
I think I will go back an dwork on my 1/35 tractor and stop complaining that it's small.
Keep up the excellent work.
Bill
Posted by Gamera on Tuesday, January 5, 2010 8:03 PM
WOW! That's awesome. Looking forward to seeing her done!
Posted by senojrn on Wednesday, January 6, 2010 8:52 AM
You sir, have my TOTAL and COMPLETE respect! Your work is simply AMAZING! The barn is fantastic looking and the aircraft are OUTSTANDING! I look forward to seeing more!!  GREAT JOB!!
    December 2008
Posted by psstoff995's lbro on Wednesday, January 6, 2010 10:26 AM
Very cool! That looks great, nice work on that shed structure especially.
-Will young modeler Test fit master
    April 2009
Posted by deafpanzer on Wednesday, January 6, 2010 12:34 PM
Ditto  That shed got me very impressed.  Thanks for posting... hope we will see more coming from you!
Andy
    January 2009
Posted by fermis on Thursday, January 7, 2010 10:01 AM
 Absolutely stunning work on the barn, looks very real. Aircraft are great as well!!!
    October 2003
Posted by lucke.stz on Tuesday, January 12, 2010 11:52 AM
thank you guys, I´m happy that my work is good :D
well, after some time with no work on this, I´m  back to the diorama...
The 262 was finished, some pics:
The little model :D :D
Here the guys the must be painted....
For now is just this...
thanks to see :D :D
    October 2003
Posted by lucke.stz on Sunday, January 17, 2010 6:10 PM
Some more pics...
Paintend a little PE bike, and start to work on the base...
Here the little bike, it has about 6mm long.
To make the base I use a wood sheet 3mm, apply some plaster to meke the ground, to the grass I use Fun Flok (that is used to make velvet effect in toys).
Some details:
I still work on some more details of the base, but is going to be a good Diorama :D :D
Thanks to see :D :D
Lucas
    October 2003
Posted by lucke.stz on Sunday, March 14, 2010 7:02 PM
The diorama is finished !
A pics thru video here :
http://www.youtube.com/watch?v=u3S-oEjtmKE
Pics about the diorama finished here:
http://www.spruemaster.com/blog/index.php/2010/03/ju87diorama-partefinal/
Best regards !
Lucas
    September 2007
Posted by SuppressionFire on Sunday, March 14, 2010 7:27 PM
Excellent diorama Lucas! You really captured the scene from the WWII photograph and insight into the condition of the Luftwaffle during the closeing days of the conflict. Looking forward to seeing more of your work posted here.
~ Jason
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    September 2009
Posted by B17Pilot on Monday, March 15, 2010 1:41 PM
Absolutely amazing work! Bow Down I for one would never have attempted it in 1/144!
    March 2010
Posted by Slynky on Friday, March 19, 2010 4:23 PM
Wow!  You're good !  (and a bit crazy ! LOL)
What a job !
    December 2004
Posted by vonryan on Friday, March 19, 2010 9:53 PM
lucke your an AMAZING modeler. very outstanding build.
Clay
    October 2003
Posted by lucke.stz on Friday, March 19, 2010 10:16 PM
Thank you to all.
I love this scale, cos you don´t need too much space to store your colection, and is possible to made nices dioramas too :D
Thank you so much.
Lucas Rizi
